spray adhesive - what's the trick?
« back to Scrollsawing forum
Forum topic by JustJoe posted 01-02-2014 11:59 PM 3146 views 3 times favorited 35 replies Add to Favorites Watch
View JustJoe's profile
JustJoe
1554 posts in 2243 days
01-02-2014 11:59 PM
I’m new to the whole scrollsawing thing. Can someone tell me please what the trick is to getting the spray adhesive to make the paper stick to the wood? I’m using a can of DURO All-Purpose Spray Adhesive (Blue can, 01-81088 might be the model #). I spray the wood, apply the paper, it peels off. I spray the paper, apply it to the wood, it peels off. Sometimes it sticks for a little bit and then when I start scrolling it lifts off and I’m stuck trying to guide the wood with one hand and hold down the pattern with the other.
I’ve tried walnut, cherry, bubinga, and next up is maple if that makes a difference.
Please advise. And if I’m using the wrong spray glue, please be very specific with what I need to buy and where (locally) I can buy it.
thanks
Joe
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
35 replies so far
View Pezking7p's profile
Pezking7p
3217 posts in 1857 days
#1 posted 01-03-2014 12:02 AM
Not sure of the adhesive, but being familiar with similar things, after you spray it you need to let the solvents evaporate before applying the paper. Should be tacky after a minute or so.
-- -Dan
View distrbd's profile
distrbd
2252 posts in 2652 days
#2 posted 01-03-2014 12:12 AM
This is how I do it,I first use painter’s tape to tape over the piece of wood I’ll be cutting,then lightly spray the painter’s tape ,wait a couple of minutes till its tacky ,then stick the pattern on it.it when finish cutting it will be easy to remove the pattern and the tape off the workpiece.
-- Ken from Ontario, Canada
View kdc68's profile
kdc68
2691 posts in 2482 days
#3 posted 01-03-2014 12:13 AM
I use Easy-Tack Repositional Adhesive by Krylon….. Instructions say spray a light coat to both surfaces and let dry for 60 seconds before you stick the two surfaces together…..Maybe that would work for your adhesive…good luck…
-- Measure "at least" twice and cut once
distrbd
#4 posted 01-03-2014 12:25 AM
I use 3M Super 77 but the brand really don’t seem to matter for this application,I also cover the whole work piece with 2” clear packing tape .
JustJoe
#5 posted 01-03-2014 12:26 AM
I may have been applying too quickly after spraying. I’ll try waiting until it gets tacky. And the tape trick is good to know too. Thanks!
View jimr1cos's profile
jimr1cos
31 posts in 2091 days
#6 posted 01-03-2014 12:44 AM
Joe, I use Aileen’s Tacky Spray(30 second wait time), but I don’t think the brand is real critical. I also cover the wood with either clear packaging tape or blue painters tape. I prefer the blue stuff.
View Pimzedd's profile (online now)
Pimzedd
612 posts in 4348 days
#7 posted 01-03-2014 12:48 AM
I put down a layer of blue painters tape. The spay glue the back of the pattern and position. Then cover with clear packing tape. Works every time.
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
View Stoli's profile
Stoli
57 posts in 3572 days
#8 posted 01-03-2014 02:12 AM
Have you tried applying the adhesive to both the paper and the wood? I recently did this by mistake and had trouble getting the paper off – had to sand it off.
JustJoe
#9 posted 01-03-2014 02:54 AM
The latest one I tried waiting 1 minute after spraying. It is sticking fine now. I didn’t use tape because it’s cold out, the tape is in the workshop, the scrollsaw is in the living room, and I’m feeling lazy. But the next one I’ll try adding tape to the wood first.
View woodsmithshop's profile
woodsmithshop
1347 posts in 3751 days
#10 posted 01-03-2014 08:09 PM
the tape acts like a lubricant and helps to cut down on splintering
-- Smitty!!!
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3790 days
#11 posted 01-03-2014 08:13 PM
Just wait a little while when it no longer raises itself when you put your finger on it or another way of saying it is touch dry,and no longer fresh wet, then apply both sides and it will stick imediately. Obviously spray both sides and wait.People who cant wait a few minutes get into all sorts of trouble and the parts raise from each other. Alistair
404 - Not Found
2544 posts in 3174 days
#12 posted 01-03-2014 08:47 PM
Look out for ‘Spray Mount’ by 3M – it’s the best of the spray adhesives in my opinion. It goes on thin and evenly without solvent coming through the paper and bubbling, also allows for repositioning without making a mess. Expensive but worth it, the Festool of spray adhesives.
View Gene Howe's profile (online now)
Gene Howe
11076 posts in 3634 days
#13 posted 01-03-2014 08:54 PM
To remove the stubborn pattern fragments, I soak the piece in lacquer thinner. The paper just rubs off after 4-5 minutes of soaking. Might need to moisten a rag and rub the piece to get all the residual glue off.
But, Ken’s suggestion would eliminate the need for the thinner.
View lumberjoe's profile
lumberjoe
2899 posts in 2453 days
#14 posted 01-04-2014 03:56 AM
I have a better trick – Don’t stick the paper to the wood. Print your pattern on a laser printer (inverse if not symmetrical. ) if you don’t have a laser printer, photocopy it. Now use a pattern transfer tool (wood burner kits come with them) and transfer your pattern. Cover it with clear packing tape on both sides. It helps keep the blades cool (true story).
I do this for chip carving as well. It sands off easily. You can also do a chemical transfer (acetone) but it’s messier, harder to transfer easily and doesn’t come off as easily.
It has to be laser printed or electrostatic photocopied. Inkjet will not transfer.
View Sk1pp3r's profile
Sk1pp3r
66 posts in 1978 days
#15 posted 01-04-2014 04:05 AM
Naptha works really well at removing the paper as well.
showing 1 through 15 of 35 replies
