Forum topic by jeffb33200 | posted 01-02-2014 11:07 PM | 2609 views | 0 times favorited | 42 replies | ![]() |
Topic tags/keywords: question tablesaw I’m considering buying a used Delta Unisaw that has a 7HP, 220V, 3ph motor. This would be for my home use so I wonder if it’s more than I should be getting. I see inverters/VFDs for sale that will convert 220V, 1ph to 3ph but what about the wiring needed for a 7hp motor. I don’t know if 7hp is what the motor is capable of delivering or if that much power will always be drawn. Anyone have some ideas about this? Thanks, Jeff |
42 replies so far
#1 posted 01-02-2014 11:23 PM |
I would avoid it if you had to use a converter. Those converters can not create power only convert it. In the conversion you lose some because they are not 100% efficient and then you end up with less available power than you would with a single phase. |
#2 posted 01-02-2014 11:32 PM |
A 7hp 3-phase motor draws approx 20-22 amps at 220V. It won’t kill your wiring if you have one decent sized ciruit. -- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium. |
#3 posted 01-02-2014 11:46 PM |
You’d almost certainly be better off either: a) replacing the motor with a ~3HP single phase 240V one or b) looking for a different saw that comes with a single phase motor. They are definitely out there on the used market. |
#4 posted 01-03-2014 12:08 AM |
For what its worth.
I ran a 7.5hp saw with one of these Autogen static converters for a year and could not stall the 14” saw.
I used the CD14, the CD 15 might have been better for spec.
These are cap run converters, basically turns a 3phase motor to run like a single phase with the cap run feature.
The specs are here, also Grizzly sells these. There are those that will claim the motor will burn out, your hair will turn orange, the paint will peel off your house using such a device, all BS. |
#5 posted 01-03-2014 12:29 AM |
You can usually get a 1ph 3hp motor for around $500, sometimes less. You could get one for a lot less if you happened upon a used one. Problem is almost all of the cheap used unisaw motors are 3ph for the very reason you’re encountering. |
#6 posted 01-03-2014 01:15 AM |
A VFD for a 7hp motor will be cost prohibitive. One alternative would be a rotary phase coverter. An RPC will run about $700. If this is your ONLY 3ph machine and you are not considering any more I would opt for a new motor. My shop is almost complete 3 phase and I do have a few VFD’s and an RPC. American Rotary makes a good panel, CNC compatible, for under $400 and can be purchased on ebay. American is a great company and they have been building RPC’s for along time and have a great customer service and technical department. A VFD will give you 100% output a static converter will NOT. Friends don’t let friends use a static converter. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#7 posted 01-03-2014 01:49 AM |
for a regular set up you only need to have a RPC 1/3 the nameplate power of the motor you are running. Capacitor balanced “static converters will give you full power IF they have been balanced for the power being used the trouble with a table saw is that the power being used is extremely variable dependent on its use. for an rpc generating 22 amps per leg out you would have to supply in the neiborhood of 45 amps per leg 220 single to the RPC side. You dont get into the high current draw very often and not for long term so IMHO you could get by on a 2 hp rpc properly protected with #10 feeds for 30 amp primary side properly protected. if you want every ounce of the power go for a 5 hp rpc and feed it with #6 a 45 amps. unbob the paint on the house turns orange, your hair falls out, and the motor becomes over-unity so you can sell the extra power back to the utility for three times the price! where do you get your information.lol |
#8 posted 01-03-2014 03:43 AM |
I have some experience with RPC as we have a 10 hp RPC. I put it together with an older 10 HP Baldor motor that came off an older air compressor that was junked or sold to me for parts. The RPC box I bought off of ebay. This said, we run our 7.5 hp shapers using our RPC but I will say it is a bit of a struggle. The motors do not seem to be getting enough power as they tend to struggle with some cuts our previous 3 hp single phase shapers would cut like butter. At this time, we are very close to getting into our new 40X80 so after the move I plan on upgrading our RPC to 20 hp. I will say that our RPC runs other things great such as our power feeders, our Blum minipress, a 3 phase unisaw (3hp), a past air compressor that was a 5 hp quincy (this has since been converted to a single phase motor)... Not to sound negative, but while I would not hesitate to go for the Unisaw purchase, even with the 7 hp 3 phase motor, I suspect you would have some challenges to overcome getting it to run at full power on single phase. We run our 10 hp RPC with #8 on a 50 amp breaker. I am no ‘pro’ when it comes to these things, I typically self teach myself and much of the time I learn by doing. As I tell my guys, ‘if I tell you something, it is based on life experience and not some book I read, it is because I have been there, done that and already screwed up in the past…’ Not sure if my personal experience is of any help. If you are only looking at one machine to run such as just the 7 hp Unisaw, a brand new Leeson single phase 5 hp replacement can be had for around 500.00 and that is the route I would go with, unless you want to add other 3 phase equipment in the future. -- . |
#9 posted 01-03-2014 06:08 AM |
My experience with the Autogen static converter is from this 7.5hp saw here I found on CL, the CL photo above. On the other note, I have only seen woodworkers do the burn up freak out over static phase converters, metal workers just complain about loss of power. |
#10 posted 01-03-2014 06:21 AM |
Some other 3phase stuff, I just have not had the problems of cooking 3phase motors some claim. So, show me what ya got. |
#11 posted 01-03-2014 06:26 AM |
You are going to need a breaker close to 100 amps 1 ph 240 to start that thing. -- Bob in WW ~ "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#12 posted 01-03-2014 06:31 AM |
Just had another thought; if you were in this area in WA, the power company would charge you to install a transformer big enough to start that without affecting your neighbors. Their lights will be blinking when you turn it on ;-) -- Bob in WW ~ "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#13 posted 01-03-2014 06:33 AM |
The price on a VFD in that range could be a deterrent. Smaller A Unisaw with a 7hp motor is not a common thing. I suspect btw – I just bought a 7.5hp wide belt sander (small one) |
#14 posted 01-03-2014 06:42 AM |
Loren, that will be interesting to see if it starts. I’ve never tried to run a 3 phase motor on a too small roto-phase. -- Bob in WW ~ "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#15 posted 01-03-2014 06:51 AM |
I’ll let you all know. |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28058 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
