A newbie asking question on rough cut lumber logs...
Forum topic by christianhgross posted 01-02-2014 03:40 PM 799 views 0 times favorited 4 replies Add to Favorites Watch
View christianhgross's profile
christianhgross
3 posts in 1516 days
01-02-2014 03:40 PM
Topic tags/keywords: fresh cut logs pine
Hi,
We bought a property that I am renovating. The other properties around us are all forest and it seems this year the neighbor has cut some mighty big pines to be used for wood block houses and plain ol lumber. I see the logs all stacked up and something struck me as very odd. It seems that about 95% of the lumber pieces are cracked as in the picture. So worse some less, but the added picture is the average. I am a newbie, but when I look at these cracks I can’t but help and think that these logs would best be served as firewood? Again I am a newbie and have no clue, but it does not seem correct. Could somebody please explain what I am seeing?
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2177 days
#1 posted 01-02-2014 04:13 PM
they are fine its the moisture coming out of the ends that causes the cracks.
View brtech's profile
brtech
1020 posts in 2831 days
#2 posted 01-02-2014 04:43 PM
It’s called “checking” and its normal. You can seal the ends of the logs to prevent it, but on inexpensive wood, it’s not worth it.
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2015 days
#3 posted 01-02-2014 07:05 PM
The checking occurs at the end, and only for the first inch or two. It happens because the end is drying faster than the rest of the log. If you seal it immediately after felling the tree, it won’t check.
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
christianhgross
#4 posted 01-03-2014 08:21 PM
ah ok I get it… Thank-you…
