Why a T-square style fence
Forum topic by jeffb33200 posted 01-02-2014 03:14 PM 1723 views 0 times favorited 17 replies Add to Favorites Watch
View jeffb33200's profile
jeffb33200
15 posts in 1479 days
01-02-2014 03:14 PM
Topic tags/keywords: tablesaw
Hi All,
I have done some woodworking and want to get a better table saw. What are the advantages to the Biesemeyer fence and their like over the old style that clamps front and back? If the fence is adjusted properly will there be any difference? Thanks for any tips.
17 replies so far
View longgone's profile
longgone
5688 posts in 3180 days
#1 posted 01-02-2014 03:18 PM
I have owned and used pretty much every style of table saw fence in the 50+ years I have been woodworking and my all time favorite is the Incra fence system.
View bbc557ci's profile
bbc557ci
595 posts in 1946 days
#2 posted 01-02-2014 03:22 PM
I would say the Bies style fence overall is stronger, and stays in adjustment better than many/most stock fences that come with a run of the mill table saw. But that said, nothing wrong with the back clampers, if they keep their set and ya don’t need to measure/fiddle with them before every cut.
-- Bill, central NY...no where near the "big apple"
View bondogaposis's profile
bondogaposis
4526 posts in 2223 days
#3 posted 01-02-2014 03:24 PM
Well theoretically if both are adjusted properly there will be no difference. I use a pretty old Craftsman 113. series table saw the fence it came with would crab toward the blade in the back when tightened. That is a kickback risk as well as making the cut off square. I would have to fiddle with it to get the fence and have to measure off the front of the blade and the back of the blade and tighten and re-tighten the fence for each cut. I got fed up with it and got a Delta T2 fence and now setting the fence is easy, quick and accurate. Saved me from buying a new saw.
-- Bondo Gaposis
View CharlesA's profile
CharlesA
3302 posts in 1670 days
#4 posted 01-02-2014 03:28 PM
The biesemeyer style fences offer rock solid stability. My shop fox classic weighs a ton bc of the box section heavy steel. One never has to worry if the stock will deflect the fence. Any they offer very fine adjustability, although usually by nudging the fence
View distrbd's profile
distrbd
2252 posts in 2318 days
#5 posted 01-02-2014 03:55 PM
The main difference in Biesemeyer type fence and others is,Biese type have one single “pinch point” as it’s called ,oppose to other types that crabs the table from front and back rails which needs constant adjustments.
Every time you move this type of fence you need to make it parallel front and back to the blade but with biesemeyer you move it to desired location and clamp it.
-- Ken from Ontario, Canada
View Grandpa's profile
Grandpa
3259 posts in 2547 days
#6 posted 01-02-2014 03:56 PM
My son-in-law was given a 113 series Craftsman saw. I was setting it up for him. Ever y time I move the fence and tightened it, I got a new angle. As Bondo said above, it would crab toward the blade. I studied it for awhile and finally saw the problem. If I locked the blade tight enough to really hold it would cause the angle iron rail to flex toward the table. The further out from the blade, the more it moved. I finally got out some precision measuring tools and decided I needed some accurate spacers made to hold the angle away from the fence. I went to a machine shop and had these made. I drilled and bolted them on. My bolts go through the angle, the space and the table. I used a nut on the back. This made the saw very usable for (in my case) no cost. I own a Unisaw with a Unifence on it. It is good but the Craftsman is very usable with some TLC. They all have to be checked periodically.
View PurpLev's profile
PurpLev
8534 posts in 3520 days
#7 posted 01-02-2014 04:10 PM
T-style VS “back-forth clamp” benefit is that when you clamp the fence down there is no change of the fence itself bowing/cupping/twisting out of straight.
that said -there are some really good back-forth-clamp fences out there. I personally found the Bosch 4100 TS fence to be excellent!
jeffb33200
#8 posted 01-02-2014 04:19 PM
To all of you,
This was my first post on here and I appreciate all the answers. Thank you.
View knotscott's profile
knotscott
7819 posts in 3248 days
#9 posted 01-02-2014 04:27 PM
It’s worth noting that there are good and poor examples of most types of fences. The beauty of the Biese style front locking t-square fences is simplicity….once setup, they’re pretty much a set it and forget it fence. They can have very good accuracy, excellent reliability, are easy to adapt jigs to, and are very easy to use in general…”goof proof” if you will. The better ones like the actual Biese and better clones are extremely rugged as well as accurate. Some of the lesser dual lockers have a reputation for locking down out of parallel.
View johnstoneb's profile
johnstoneb
2692 posts in 2045 days
#10 posted 01-02-2014 05:31 PM
+1 Bondo Gaposis. I had same problem with my 113 the T2 fence saved me from buying a new saw. The T2 clamps square and stays that way. The Biesmeyer uses the a similar system.
-- Bruce, Boise, ID
View toolie's profile
toolie
2101 posts in 2500 days
#11 posted 01-02-2014 11:51 PM
no. my puny ridgid 2412 has a front/rear locking OEM fence system adn it locks true (+/-.001”) every time, just like th edelta t2 on my other emerson electric built TS, a 113 series c-man.
maybe with certain c-man OEM fences, but not with all front/rear lock fences. i wouldn’t change the fence on my 2412 for anything. and if the WOOD magazine projects are checked carefully, there are many projects whose parts are fabricated on a ridgid 3650 (with OEM front/rear clamp fence).
View Woodbum's profile
Woodbum
800 posts in 2937 days
#12 posted 01-03-2014 08:48 PM
+1 on Greg the Cajun Box Sculptor’s comment. I really like my Incra TSIII fence system.
-- "Now I'm just another old guy wearing funny clothes"
View pintodeluxe's profile
pintodeluxe
5544 posts in 2685 days
#13 posted 01-03-2014 08:57 PM
To this very day, my dad measures at the front of the blade and at the back of the blade to the fence.
That is reason enough to use a T-square style fence. Set it and forget it. I have the Jet Xacta II and it is solid.
View Gentile's profile (online now)
Gentile
291 posts in 1690 days
#14 posted 01-28-2014 11:22 PM
On my delta TS, the stock fence was terrible. I could not afford a Besiemer upgrade. The woodworkers store carried Steel City machines. I picked one of there’s up. It’s basically a clone of the Besiemers. It works great!
-- "I cut it twice and it's still too short"
View lightcs1776's profile
lightcs1776
4183 posts in 1526 days
#15 posted 01-28-2014 11:55 PM
Big difference if you want repeatable cuts that are accurate. I have a 113 series Craftsman. The saw is sufficient for what I want to make, but the fence needs a lot of attention every time it is moved. I have to be very careful not to get in a hurry and fail to check the fence. Unfortunately a decent fence isn’t cheap, costing at least $200 and likely $300 and up.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
