How to make this Snapp cutting board
Forum topic by SPalm posted 01-02-2014 02:09 PM 2301 views 7 times favorited 40 replies Add to Favorites Watch
View SPalm's profile
SPalm
5325 posts in 4118 days
01-02-2014 02:09 PM
Topic tags/keywords: snapp cutting board
Here is a board that I found that has a taper in it to help with scraping off the cuttings. Kind of clever, not sure if useful, but unique none the less. The taper on the reverse side doubles as a hand hold. Here are pics from the manufacture.
This is how I tried to make it. I made a matching set of 30/60 degree angles. Clamped that to a 90 degree reference and slid it through the table saw with the blade at max height and a slight tilt. Then flipped the board and used the other set of angles for the other side of the board. I guess it worked, but the blade only goes 3.5 inches high. Then I glued on the side strips. This was only on scrap cherry, so it is kind of ugly. Thicker board might help too.
How would you do it?
Steve
-- -- I'm no rocket surgeon
40 replies so far
View PurpLev's profile
PurpLev
8548 posts in 3884 days
#1 posted 01-02-2014 02:22 PM
very cool.
Steve, I think your method is as safe and easy as can be that I wouldn’t think twice about an alternative way to do this.
View lew's profile
lew
12495 posts in 3991 days
#2 posted 01-02-2014 02:29 PM
+1 for what Sharon said!
SPalm
#3 posted 01-02-2014 02:33 PM
But the cut does really not go ‘wide’ (tall) enough. 3.5 inches is pretty small. Maybe I should get a table saw with a 12 inch blade :)
Or drag the cut across the jointer a couple of times to widen it. Kind of a scary thought.
Steve
View stefang's profile
stefang
16209 posts in 3570 days
#4 posted 01-02-2014 02:33 PM
You did this in a great way Steve. If I wanted a solid board I would probably just use a sharp chisel, a cabinet scraper and some sandpaper. That said there aren’t too many boards that wide readily available, so I think your method would probably be the most effective method for most of us.
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3341 days
#5 posted 01-02-2014 02:44 PM
Hi Steve. I would probably mount it on the wierd angle on a fixture in my mill vise and cut it with a 1 1.2” router bit in the mill/.
I think it can be cone on a router table with a similar set up to make that corner low and just keep passing it over and moving the fence.
I’ll bet Izzy Swan might have a table saw fixture to do it already!! He can make a bowling ball on the table saw….Jim
View Woodwrecker's profile
Woodwrecker
4211 posts in 3811 days
#6 posted 01-02-2014 03:26 PM
I think you have the right way to go there Steve.
Thanks for showing us.
View KnotCurser's profile
KnotCurser
2031 posts in 3304 days
#7 posted 01-02-2014 03:35 PM
Ever thought of using your CNC Router for this?
That’s the first idea that came to my mind….........
-bob
-- Robert Rhoades WoodWorks / Email: rrww@rhoadesclan.com / www.rhoadesclan.com
SPalm
#8 posted 01-02-2014 03:40 PM
I have thought about the CNC, router table, drum sander, etc. The problem is with them is that the board really is up in the air and kind of unwieldy. And I believe it would not fit.
Of course there is always hand tools.
Steve
View rance's profile
rance
4267 posts in 3396 days
#9 posted 01-02-2014 03:50 PM
Steve,
If I were doing multiples, I would opt to put it on a sled and run it through the planer. No other good way IMO. I’d prop it up on three corners & fasten with double sided tape and the front corner that is the lowest, I’d clamp that down with a wooden clamp & a brass screw. Also have a cleat in the rear to prevent shearing tendencies of the tape. That tape is REALLY strong if you get the thick stuff.
2nd choice would be fasten it down and run a hand-router over it like folks do with that router trough.
For only one, I would strongly consider just sanding it down with a 6×48 belt sander. Mark the outline and then sand down to it. 1st choice 36 grit, 2nd choice 80 grit.
View Paul Miller's profile
Paul Miller
33 posts in 3689 days
#10 posted 01-02-2014 03:55 PM
I’m not really a big hand tool guy, but I think I’d just use a hand plane.
Paul
PurpLev
#11 posted 01-02-2014 04:08 PM
If you want wider, you can also do the same cut – with same setup, but on the bandsaw and either tilt the BS table, or create the bevel in the sliding fixture. in which case you will only be limited by the capacity of your saw (mine can do up to 13” for reference).
View shipwright's profile
shipwright
8185 posts in 3034 days
#12 posted 01-02-2014 04:11 PM
I almost hate to say this Steve, but my go to tool would be the bandsaw with a simple angle brace
.............. but I do several things that I would not recommend to anyone else. In boat building I’ve often freehand sculpted things that way but I think yours is the right way.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1963 days
#13 posted 01-02-2014 04:29 PM
Surprised no one has mentioned the RAS with a dado blade. Propped up right, I think it could be done very safely, with just a little clean up afterwards. You wouldn’t be limited to the size of your blade for the height.
117417 posts in 3813 days
#14 posted 01-02-2014 04:41 PM
I haven’t seen this design before ,Thanks for sharing the idea and your process.
View Nicky's profile
Nicky
695 posts in 4327 days
#15 posted 01-02-2014 04:45 PM
That is a very cool design. I think your method is sound, I’d be curious to see what others may suggest.
-- Nicky
showing 1 through 15 of 40 replies
