Plyo Boxes
« back to Joinery forum
Forum topic by Robert Smith posted 01-01-2014 11:00 PM 4453 views 0 times favorited 3 replies Add to Favorites Watch
View Robert Smith's profile
Robert Smith
18 posts in 1736 days
01-01-2014 11:00 PM
I just got finished building these stackable plyo boxes. I used the pocket jig and but joints. It just took forever to assemble and no mater what I did it was hard to line up the joints. What can I do to get more accurate corners to minimize my sanding and routing.
-- Robert
3 replies so far
View Fargo3's profile
Fargo3
2 posts in 1738 days
#1 posted 01-01-2014 11:18 PM
Hey Columbus, did you use the Kreg Right Angle Clamp. I have found that these are indespensible when using pocket screw construction. If I need to insure decent alignment I also spend the time to make a 90 degree jig to clamp against.
Robert Smith
#2 posted 01-01-2014 11:30 PM
No I just pinned pinned a piece of wood to keep it straight. What’s a 90 degree jig?
-- Robert
View ShaneA's profile
ShaneA
6955 posts in 2622 days
#3 posted 01-01-2014 11:35 PM
A jig used to clamp the pieces during assembly @ 90°. The kreg screws can make the pieces creep, if not properly secured. Cutting all like pieces at the same time w/same table saw/fence/stop settings will help to yield identical parts. Plus make sure your table saw is tuned up and dialed in, in terms of blade at 90° and fence parallel to the blade. Before attaching back, make sure you are square, and clamped if need be.
