Powermatic 72 vs 66 Table Saw
Forum topic by Kyheadhunter posted 01-01-2014 09:58 PM 12372 views 0 times favorited 24 replies Add to Favorites Watch
View Kyheadhunter's profile
Kyheadhunter
40 posts in 1665 days
01-01-2014 09:58 PM
I let a powermatic 66 slip thru my finger tips a week ago, but I’ve located a PM 72. I can’t find alot of info on the 72, can a few folks chime in and help me out a bit?
24 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2063 days
#1 posted 01-01-2014 10:04 PM
Hope it didn’t land on your toes.
OWWM is your friend, you should find a manual and description here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=655&tab=4
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View cabmaker's profile
cabmaker
1735 posts in 2833 days
#2 posted 01-01-2014 10:28 PM
The 66 is a toy in comparison.. Should have a one inch arbor. Will be either a 5 hp (1 or 3 phase) or a 7.5 hp 3 phase.
Much more cast iron on top than a 66
Will weigh near 900 lbs.
Original fence brawny but slow in use ( that is if still equipped with orig.
Very smooth operator if in fair to good condition
It likely will not have all the Mickey Mouse junk on it ie: Irving knife, etc.
You will never need another
JB
Kyheadhunter
#3 posted 01-01-2014 10:30 PM
JustJoe: I was wearing steel toe shoes. :)
Cabmaker: Great info, any idea on fair price/value, overall condition unknown.
cabmaker
#4 posted 01-01-2014 10:38 PM
If it has a bies. Fence on it and good working order, 1000.00 would not be out of line.
They can often be had for 5-800.00 with orig. fence
The top is very impressive as you will have much more surface from the front edge to the blade.
Lots of reasons these machines can be had cheap is due to their mass.
It’s not one you want to put on a dolly and roll it into a corner.
Power requirements typically exceed that of a typical hobby shop.
It is a nice machine and designed for work
Kyheadhunter
#5 posted 01-01-2014 10:41 PM
I have a 400 amp service and its its 3 phase I would probably put an inverter on it.
View CharlesA's profile
CharlesA
3329 posts in 1822 days
#6 posted 01-01-2014 10:44 PM
Note that, according to the vintage machinery website, it takes a 12-14” blade.
cabmaker
#7 posted 01-01-2014 10:46 PM
Know too that 35 years ago that was a 5000,00 saw. That should tell u something. Go get it
Kyheadhunter
#8 posted 01-01-2014 10:50 PM
WOW, $5000…...................That is alot of GREEN.
View toolie's profile
toolie
2134 posts in 2653 days
#9 posted 01-02-2014 01:08 AM
No fan of new PM stuff here, but a 72 in good condition for a fair price would be hard to pass up, especially if it had the optional CI right side extension wing. I saw one once and it looked absolutely MASSIVE!
View unbob's profile
unbob
810 posts in 1928 days
#10 posted 01-02-2014 02:52 AM
I have a 72A, and the Delta 12”-14”.
Both great saws. the extra 6 to 8” in front of the blade is really nice for me.
I agree these saws should be mounted directly to the floor, no wheels.
After using these saws, 10” models are terrible, blade right in your face, little room up front and wimpy 5/8” arbors.
Kyheadhunter
#11 posted 01-11-2014 05:13 PM
After letting the PM 66 slip away, I was able to snag a PM 72 today. Got it for $575. Now I need to decide on a new motor since mine is 7.5 3 phase or get a rotary phase converter. A VFD for this size motor is probably out of the question, and a new motor goes for around $600, with a rotary phase converter going for between $900-1000. Since this is my first piece of equipment, a rotary phase converter would set up up for other 3 phase equipment. Thoughts?
View Loren's profile
10476 posts in 3672 days
#12 posted 01-11-2014 05:22 PM
You can build a rotary converter cheaper in a few hours
using a box from Phase-craft and an idler motor you
scrounge yourself locally.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR3.TRC1.A0.Xphase-craft&_nkw=phase-craft&_sacat=0&_from=R40
I bought a 5hp box from the guy and the motor
cost me another $100. I could have found one for
less but I was in a hurry to get the phase converter
up and running.
Setting up for 3 phase is a great step to take if you
take machine woodworking seriously.
A 10hp rotary converter will run just about anything
you might acquire for use in a one-person shop
except something like a big wide belt sander
or industrial CNC machine.
JustJoe
#13 posted 01-11-2014 05:22 PM
A quick search of TemCo didn’t show any single-phase input, 3-phase output with 7.5hp or larger for under a grand, so it looks like yes a phase converter is your best bet. And a RPC will allow you to hook up multiple machines (I hook up multiple machines to my VFD too – I put a female locking plug on the output and just plug/unplug the machine I need).
There are enough 3-phase machines out there to make it worth going that route rather than replacing the motor. And if you can find another 3-phase motor to use as the idler, then it wouldn’t even cost you $900. You can get the rest of the converter minus the machine on fleabay for just a couple hundred.
cabmaker
#14 posted 01-11-2014 05:26 PM
We’re it me I would replace with a single phase 5hp.
If your objective is to actually use the saw,that is.
No lost time in tinkering around with converters, with which come additional costs and taking up more space,etc.
You will likely need to address the switch to some degree as it is probably set up with heaters and will be a three ple configuration. You will be able to use it but I won’t attempt to get into that online . I’m am no expert on that,but many guys here can detail that for you.
Congratulations on the buy! Think about a bies . Fence setup. No need to cut corners now!
Kyheadhunter
#15 posted 01-11-2014 05:33 PM
I appreciate the input. As a note, I’m an electrician so the electrical side of any installation is covered at no cost except materials.
