Triming trim
Forum topic by Sawdust2012 posted 01-01-2014 01:44 PM 704 views 0 times favorited 5 replies Add to Favorites Watch
View Sawdust2012's profile
Sawdust2012
123 posts in 1711 days
01-01-2014 01:44 PM
I need to take about 1/4” off of a couple of 3’ pieces of trim i routed and cut on a table saw. What is the best way to do this? I dont have unrestricted access to a table saw, so I cant easily recut the trim. I am wondering if it is safe to use a band saw for this? I have a 1/8” blade with a fairly high tooth count and am hoping that would produce an edge smooth enough to glue to the base. Any thoughts?
5 replies so far
View WibblyPig's profile
WibblyPig
172 posts in 3273 days
#1 posted 01-01-2014 02:32 PM
I’d use a shooting board and a block plane.
-- Steve, Webster Groves, MO "A society grows great when old men plant trees whose shade they know they shall never sit in."
View waho6o9's profile
waho6o9
8191 posts in 2576 days
#2 posted 01-01-2014 02:49 PM
I’d listen to WibblyPig, good advice right there ;)
View Bluepine38's profile
Bluepine38
3379 posts in 3084 days
#3 posted 01-01-2014 07:45 PM
1/4” is a bit to take off with a block plane, unless you are very good with a plane. I would use one of
my fine tooth backsaws or Japanese type pull saws with a miter box. On a band saw, you would have
quite a bit hanging out without any support, which could cause a problem.
WibblyPig
#4 posted 01-01-2014 09:26 PM
I believe he’s saying that he needs to take off 1/4” off the length of the molding, not the miter or end.
Sawdust2012
#5 posted 01-01-2014 10:46 PM
I actually needed 1/4” out of the width. I ended up doing it with a bandsaw. I was woried about the edge that would be left, but it worked out great.
