Table Saw Blade for Resawing
Forum topic by docspencer posted 01-01-2014 01:16 PM 1408 views 0 times favorited 11 replies Add to Favorites Watch
View docspencer's profile
343 posts in 1880 days
01-01-2014 01:16 PM
I’ve been reading all I can find about resawing with my table saw. So far, I have been using my 10” 60 tooth but it tends to burn when cutting oak. From what I’ve read, I should be using a 10” 24 tooth and my local HD has a Diablo for $28. I trust you collective opinion on this site – is this a good choice?
11 replies so far
View jonah's profile
1626 posts in 3233 days
#1 posted 01-01-2014 01:43 PM
The Diablo thin kerf rip blade you’re talking about a fine blade for what you’re doing. It’s a good-but-not-great option. To get an unequivocally better rip blade, you’ll need to spend probably twice as much or more.
#2 posted 01-01-2014 05:27 PM
Thanks, jonah. Just for grins, what brands make a “unequivocally better rip blade” – just in case my wife actually lets me spend that kind of money :)
View DKV's profile
3940 posts in 2438 days
#3 posted 01-01-2014 05:42 PM
Be nice to the wife and buy a blade. Take her shopping with you.
-- This is a Troll Free zone.
4909 posts in 2427 days
#4 posted 01-01-2014 05:52 PM
Take a look at the Freud P410, or the Forrest WWII ripping blade.. There’s several others, but the exact model escapes me at the moment.
View knotscott's profile
7938 posts in 3310 days
#5 posted 01-01-2014 07:29 PM
Burning can become a problem with too many teeth, so I’ve always stuck with 24T or less. The Diablo has an ATB grind vs flat, but is otherwise fine. I prefer the Freud LU87, Infinity 010-124, or DW7124PT…all flat top grinds (FTG).
10102 posts in 3582 days
#6 posted 01-01-2014 07:38 PM
It’s probably fine. Sears has good prices on decent blades. As
log as you’re not trying to rip glue joints, any 10” blade
with a relatively low tooth count will do ok for resawing
on the table saw. A thin kerf blade will cut faster
unless you have 3 or more hp under the hood.
View Danpaddles's profile
573 posts in 2246 days
#7 posted 01-01-2014 07:42 PM
I have been using a 50 tooth Freud for everything. Model number not visible under the (unneeded) stabilizer. It is a higher end blade. I get a bit of burning in cherry. Keeping the blade clean makes a world of difference, get the resin off the side of the teeth, I use simple green. Faster feed helps a lot too. Pause while pushing the board and you will spend some time sanding.
I am sure a blade with fewer teeth would help on rips. But I like the luxury of not changing blades every time I change the cut I am making.
This Freud cuts cleaner and smoother than a buddies Forrest did, when he took it out of the package. I am very sold on Freud. Router bits seem to hold up well too, tho Whiteside has thicker carbide.
-- Dan V. in Indy
View Huds's profile
24 posts in 1540 days
#8 posted 01-01-2014 08:08 PM
I have both the Freud 24T flat tooth thin kerf and the 30T TCG full kerf blades, both with the permashield coating. I also have a Tenryu 50 combi and a Forrest 40T that came as a gift with the saw. Prefer the 30T TCG for ripping. Though the 30T makes more waste, it is a great ripping blade, for what it’s worth. Whether or not you get a “glue line” cut depends on a lot of factors that go beyond the saw blade – built up tension in the lumber, saw set up, fence alignment to just name a few.
View Jim Finn's profile
Jim Finn
2641 posts in 2856 days
#9 posted 01-01-2014 09:21 PM
I have that 24 teeth Diablo and use it for riping and for re-sawing. Works well for me.
Shawn Masterson
1324 posts in 1882 days
#10 posted 01-02-2014 01:40 AM
I use a cheap irwin 10” 24t that is coated to resist treated lumber. It was like $15. I really don’t care what the cut looks like, because it will get planed off. The blade cuts fast and smooth. for what I use it for I see no need to spend a lot of money on a fancy blade. also I have used the blade for 5-6 years for all my resawing needs, and it is still sharp.
View TaybulSawz's profile
156 posts in 1616 days
#11 posted 01-02-2014 03:56 AM
If kerf size is not an issue then I don’t see an issue with getting a cheap 24 tooth rip blade and going to work. If it’s sharp, flat and stable, it will do a good job for you. As previously stated, you will prolly be doing some jointing and planing anyway so who cares what kind of finish it yields.
-- Still got all my Fingers!!!
