Polshing plane parts (not brass)
« back to Hand Tools forum
Forum topic by lateralus819 posted 12-31-2013 09:52 PM 1092 views 0 times favorited 19 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1918 days
12-31-2013 09:52 PM
Curious if any of you found products that can bring a high polish to the sole and sides of a plane? The wire wheel works good and gives it a nice shine, but was looking for something a little shinier.
19 replies so far
View crank49's profile
crank49
4032 posts in 2999 days
#1 posted 12-31-2013 10:13 PM
Sure. Just take it through the grits on finer and finer SC paper. Just like you do to sharpen using the “Scary Sharp” method. You can create a mirror surface if you wish.
View Don W's profile
Don W
18756 posts in 2596 days
#2 posted 12-31-2013 10:24 PM
and/or buy some polishing wheels and compound.
lateralus819
#3 posted 12-31-2013 10:30 PM
Forgot to mention, would rather not go the sandpaper route.. takes forever. How do the wheels and compounds work don? I use a polishing compound for brass and it works wonders, not so much on the cast iron.
Don W
#4 posted 12-31-2013 10:33 PM
It depends. You have to get it to some resemblance of smooth with sandpaper first. Usually to at least 600 grit.
View ToddJB's profile
ToddJB
7991 posts in 2159 days
#5 posted 12-31-2013 10:52 PM
This is my go to http://www.amazon.com/gp/aw/d/B002P51S72
-- I came - I sawed - I over-built
lateralus819
#6 posted 12-31-2013 10:54 PM
Actually i was checking those out. I noticed your planes look REALLY shiny, do you do any work prior to using them?
View Bill White's profile
Bill White
4950 posts in 3989 days
#7 posted 12-31-2013 11:09 PM
Isn’t that a little too much? Mirror finish on a plane? Why, unless that’s just what ya want?
OK! My contribution:
Some MAAS metal polish and rubbed in with aluminum foil. That’ll work pretty well.
Bill
-- bill@magraphics.us
ToddJB
#8 posted 12-31-2013 11:32 PM
If its tarnish or rust the wheel is all I use. If it has gunk on it I’ll clean it first then use the wheel. And it goes very quick in my opinion. I use it on all steel and iron.
lateralus819
#9 posted 12-31-2013 11:35 PM
What if the iron is clean, such as after a bath in evaporust, its fine to use?
ToddJB
#10 posted 01-01-2014 12:12 AM
That’s what did.
lateralus819
#11 posted 01-01-2014 12:12 AM
Cool! Was just curious if it could hurt the metal or not.
ToddJB
#12 posted 01-01-2014 12:19 AM
If you really push hard for extended amounts of time it will get too hot to touch, but I don’t think its ever gotten hot enough to effect temper.
lateralus819
#13 posted 01-01-2014 01:05 AM
I was speaking in terms of eating through the metal.
ToddJB
#14 posted 01-01-2014 01:12 AM
Not that I experienced bit I’m sure you could go over board
Don W
#15 posted 01-01-2014 01:23 AM
the reason most users do not get polished is the work it creates trying to keep a user in that condition in the shop. You’ll spend more time wiping off finger prints than planing wood.
