Help with repair of #6 hand plane
« back to Hand Tools forum
Forum topic by DocSavage45 posted 12-31-2013 07:52 PM 1335 views 0 times favorited 22 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8453 posts in 2746 days
12-31-2013 07:52 PM
Topic tags/keywords: plane repair
Stumpy suggested I ask the LJ’s for help in identifying and locating parts for my Dad’s #6 no name plane.
Attempted to upload pictures on previous forum entry. Fixes are simple if you know wht buttons to push!
-- Cau Haus Designs, Thomas J. Tieffenbacher
22 replies so far
View JayT's profile
JayT
5522 posts in 2115 days
#1 posted 12-31-2013 07:58 PM
What parts are needed? It looks complete in the pictures.
DocSavage45
#2 posted 12-31-2013 08:04 PM
doesn’t adjust very easily and the screw is chewed up in the slot. Want to replace as much as I can to improve blade movement.
View JustJoe's profile
JustJoe
1554 posts in 1942 days
#3 posted 12-31-2013 08:10 PM
The shiny brass knob tells us someone has already started cleaning or at least messing with the plane.
Is it hard to adjust because the lever cap is on tight? How easy is it to adjust the blade forward/back with it off completely? What screw is chewed up in what slot?
As for ID – no markings on the cutter? Any numbers or letters underneath the lever cap, or under the frog?
I can’t tell, it’s a bit dark – does it have a lateral adjustment lever?
Are there any markings in the middle of the chipbreaker?
EDIT: Are there any markings inside that newly shined brass adjustment knob?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View grizzman's profile
grizzman
7836 posts in 3207 days
#4 posted 12-31-2013 08:11 PM
well from previous experience i have dipped the planes into the multiple cat sand and i see you have that already, so maybe that will work,,,,lol….sorry doc, i guess since i dont get out much i tease sometimes….the plane looks like a fun fixer upper..good time fixing it up
-- GRIZZMAN ...[''''']
View Don W's profile
Don W
18604 posts in 2471 days
#5 posted 12-31-2013 08:28 PM
What Joe said and
A picture of the lateral, frog and frog base may give some clues as well.
Sometimes just a good wire wheelin will take care of this.
And some light restoration reading if you’re bored.
DocSavage45
#6 posted 12-31-2013 08:31 PM
JOE,
WILL LOOK LATER WHEN I GO OUT TO SHOP. I”M THE GUY WHOS MESSING WITH IT. sharpened THE BLADE. HAS ADJUSTMENT LEVER.
Don W
#7 posted 12-31-2013 08:36 PM
I made an assumption with my last post. If the cap and cutter is off, does the adjustment turn any easier? If so, you may just have the cap to tight
DocSavage45
#8 posted 12-31-2013 08:40 PM
THANKS
HELP IS NEVER BORING! lol! WILL TAKE ALL SUGGESTIONS AND APPLY…:)
View Deycart's profile
Deycart
444 posts in 2162 days
#9 posted 12-31-2013 09:07 PM
Also a adding a bit of 3in1 oil to the adjustments and the face of the frog can sometimes act like magic. I didn’t do this for years but after I tried it out I went though my whole stable and did all my planes. Another place to add oil in on the rod that holds the yoke to the frog.
DocSavage45
#10 posted 12-31-2013 11:09 PM
Good ideas,
Where can I purchase parts?
Don W
#11 posted 12-31-2013 11:12 PM
http://lumberjocks.com/donwilwol/blog/24092 for a list of parts dealers
View ShaneA's profile
ShaneA
6889 posts in 2502 days
#12 posted 12-31-2013 11:15 PM
I don’t know that it has been established that you need any new parts yet. Maybe a new screw for the lever cap? With the pane taken apart, cleaned, lubed and pics taken you will get the needed info as far as ID, needed parts, if any, and how to spruce it up. We still need a better look at it, probably disassembled.
JustJoe
#13 posted 12-31-2013 11:22 PM
JOE,
Why are you yelling at me? Did I say something to piss you off, or do you think that just because I’m old I’m hard of hearing?
DocSavage45
#14 posted 12-31-2013 11:29 PM
LOL!
Probably the latter Joe.
But I was typing in caps on my insurance billing. LOL!
Will yell at ya later?
DocSavage45
#15 posted 12-31-2013 11:31 PM
Know the screw slot is messed up from a bad screwdriver. And aren’t those left handed threads?
