Unisaw adjustment
Forum topic by CGW posted 12-31-2013 03:54 PM 1250 views 0 times favorited 4 replies Add to Favorites Watch
View CGW's profile
CGW
2 posts in 1726 days
12-31-2013 03:54 PM
I am attempting to readjust the stop to aline the blade to the table at 90 degrees. I can see the 45 degree stop through the slit in the front. After checking the manual, I set the saw on it’s front side. How do I reach in there to find the stop much less do the adjustment?
5069 posts in 2611 days
#1 posted 12-31-2013 05:13 PM
The one on mine can be accessed through the motor cover. The bolt/locking nut should be visible and accessible from the motor cover. My saw is a right tilt, I’m only guessing but it seems like it might be the same on a left tilt.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2190 days
#2 posted 12-31-2013 11:24 PM
I WILL CONFIRM IT IS THE SAME ON THE LEFT TILT IS THE SAME.
-- Who is John Galt?
View toolie's profile
toolie
2143 posts in 2746 days
#3 posted 01-01-2014 03:44 PM
Do yourself a favor and back them out as far as possible. With sawdust that can accumulate inside the cabinet, on many surfaces, they will not be terribly accurate for long. I don’t use the stops on any of my saws, preferring to set bevel angles with either drafting squares or a wifey digital angle cube.
View CGW's profile
CGW
#4 posted 01-03-2014 02:18 AM
Turns out the problem was a build up of sawdust in the gears. I blew it out and – wala – problem solved. Thank you hugely for your suggestions.
