Forum topic by kmetzger | posted 12-30-2013 06:52 PM | 934 views | 0 times favorited | 5 replies | ![]() |
The handle for the speed selector assembly on our school’s Jet lathe 1442 just fell off and I can’t figure out how to re-attach it. It looks like I’ll have to get inside the headstock to see what’s going on. The manual isn’t much help because it doesn’t show how to open up the headstock to get to the speed selector. Help appreciated. http://www.rockler.com/tech/708358K_man.pdf Kim -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
5 replies so far
#1 posted 12-30-2013 08:06 PM |
Recommend calling tech support at 1-800-6848 and asking how to make the repair even if lathe is out of warranty. Looking at the diagram have to remove back cover but that does not tell me what to do next, or need to remove headstock off the lathe to get at the speed controller. http://content.jettools.com/manuals/m_708358k.pdf -- Bill |
#2 posted 12-30-2013 08:42 PM |
I would start with removing the headstock, so you can move it around and really see what you are doing. Then it sounds like exploratory surgery from there. |
#3 posted 12-30-2013 09:06 PM |
Fixed it. The rod that the handle fits onto had slipped into the headstock because a set screw had come loose. After opening the cover, I poked the rod from behind with a stick and it protruded again so that I could lock the handle with the set screw. The rod is pretty tricky to see and get to. -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#4 posted 12-30-2013 10:22 PM |
Way to go Kim, you the man! -- Bill |
#5 posted 12-30-2013 11:26 PM |
After all, a “poke with a stick” is sometimes the best method. -- bill@magraphics.us |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2107 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28057 |
CNC Woodworking
212 |
Hand Tools
5409 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
