Forum topic by Charlie75 | posted 12-30-2013 05:44 PM | 1395 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: craftsman 12432607 boxes band saw Hi, Long time lurker finally posting. I have a 14” Chraftsman band saw (#124.32607) After seeing a band saw demonstration by Scott Phillips and watching several videos on the subject of making boxes I have the itch to try my hand at it. Charlie -- Charlie75, Alto |
21 replies so far
#1 posted 12-31-2013 02:03 AM |
Should be fine with 3/16 or even 1/8” blades IF you can adjust your guides to support the blade without contacting the teeth. (or buy a Carter Stabilizer, I love mine). -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#2 posted 12-31-2013 02:51 AM |
Charlie75 do you have any problom with drift at frist when you cut in to the wood. |
#3 posted 12-31-2013 11:20 AM |
Not really. These is very little drift. -- Charlie75, Alto |
#4 posted 12-31-2013 11:24 AM |
“Should be fine with 3/16 or even 1/8” blades IF you can adjust your guides to support the blade without contacting the teeth. (or buy a Carter Stabilizer, I love mine).” What kind of saw do you have, gfadvm? -- Charlie75, Alto |
#5 posted 12-31-2013 12:00 PM |
I typically do a lot of my box work on a Porter-Cable you buy at Lowes. I often use a 3/16 or 1/8” blade, and just carefully adjust the guide wheels. I don’t have the Carter add-on, but do have guide bearings on top. I see no reason why you cannot do it. -- Tsunami Guitars and Custom Woodworking, Cleveland, TN |
#6 posted 12-31-2013 06:15 PM |
I take it then that the PC band saw has roller bearings and not cool blocks. Next time i’m in Lowes I will take a look at that saw to see if there is much difference between it and mine. Next time I’m in Wood Craft I will see if they have a 3/16 for my saw. Thanks for your reply. -- Charlie75, Alto |
#7 posted 01-01-2014 01:25 AM |
I have a 17” Grizzly Extreme Series and a 14” old Ridgid that was given to me (I posted the restoration). I made my own adapter so I can use the Stabilizer on either one. They are a little pricy and it looks to me like they would be simple to make with a grooved bearing, some metal, and a mig welder. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#8 posted 01-01-2014 03:15 AM |
Do you have any pictures of your adapter? I had wondered if there were a way to groove a bearing. How did you make your adapter? -- Charlie75, Alto |
#9 posted 01-01-2014 03:56 AM |
http://lumberjocks.com/gfadvm/blog/35910 machinist would be the one to ask about grooving a bearing (or maybe buy one with a groove already milled into it) -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#10 posted 01-01-2014 07:07 PM |
Before going to that trouble I would contact Carter and inquire about their stabilizer. -- Charlie75, Alto |
#11 posted 01-01-2014 07:50 PM |
I did a few band saw boxes a few years back. They turned out nice, but I gave it up when my second blade dulled after 4 or 5 boxes (or was it like 2 or 3?). First one did not last any longer. I used Timberwolfs. The short blade life (3/16 with a lot of teeth) added to the fact that you can use almost a whole board to make one box, caused me to give it up. -- Dan V. in Indy |
#12 posted 01-01-2014 11:27 PM |
I’m not following you around the boards Charlie. Really I’m not LOL. I’ve used a 3/16” blade on my Craftsman saw without any problem. Never made a band saw box but maybe I will one day. |
#13 posted 01-02-2014 04:32 PM |
Rob, You can follow me all you wish. I value your input. As soon as I can get my hands on a 3/16” I am going to give it a try. what tpi do you have in the 3/16? -- Charlie75, Alto |
#14 posted 01-02-2014 05:07 PM |
Charlie, I have both the 4 and 10 tpi in the 3/16” blade. I use both equally depending on the project. |
#15 posted 01-02-2014 08:20 PM |
Thanks Rob. I am going to order a 3/16” this afternoon. I am still thinking about the 10 tpi. These comments have been flying through so fast that I have forgotten. What saw are you using? If it’s like mine are you using cool blocks or stock bearings? Charlie -- Charlie75, Alto |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4755 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
