Problem with my steps cutting board (help, please)
Forum topic by nailbanger2 posted 12-30-2013 02:57 AM 967 views 0 times favorited 6 replies Add to Favorites Watch
View nailbanger2's profile
nailbanger2
1041 posts in 3111 days
12-30-2013 02:57 AM
Topic tags/keywords: question walnut sander router sanding
I just flattened my board, and I ran into a problem. I am having tear out on the walnut parts.
I don’t think the router did this. I used a dish cutting bit from MLCS that stated the bottom was flat. Not exactly. I ended up with a scalloped, or fluted finish. The first side I used my ROS with 80 grit on it to even it out so I could flip it and flatten the other side. Once that side was done, I used a belt sander with 60 grit briefly, then went with the ROS. I think the belt sander did the tear out. The router bit is not a problem any longer, as I won’t use it again.
Has anyone had this happen to them? I haven’t worked with walnut end grain before, and the walnut is the only wood affected. Is there a food safe filler I could use? I can reflatten, but I’d rather not. This is the first one I’ve done, and will be sitting on my counter, whereas I’d like to figure this out before I make one for another niece’s wedding.
-- Wish I were Norm's Nephew
View degoose's profile
degoose
7228 posts in 3323 days
#1 posted 12-30-2013 08:11 AM
Lash out on a drum sander…
View Tony_S's profile
Tony_S
857 posts in 3051 days
#2 posted 12-30-2013 11:04 AM
It’s a little bit difficult to see in any great detail, but it doesn’t look like tearout on my monitor. It looks like checking.
A closer, more detailed picture would help.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View bigblockyeti's profile
bigblockyeti
5098 posts in 1689 days
#3 posted 12-30-2013 11:54 AM
I use a belt sander on mine exclusively for the first part of sanding. After starting with what I consider a very flat glue up, usually made from hard maple, walnut and purple heart, I start with 32g, then 60g, 80g, and 120g. After those first four grits, I move to the ROS and progress on through 240 grit then finish. I’ve made less than a dozen boards this way, but never had any kind of tear out or anything that resembles what you’re experiencing.
nailbanger2
#4 posted 12-30-2013 12:16 PM
Thank you for your comments. I’ll take more pics tonight after work.
View SPalm's profile
SPalm
5317 posts in 3850 days
#5 posted 12-30-2013 01:26 PM
Wow. What a nice tight glue up. Sucks with the problem you are having.
It looks to me like the belt sander had some aggressive grit in it since the grooves are all the same direction regardless of the walnut orientation. I guess you got some more sanding to do.
Sorry,
Steve
-- -- I'm no rocket surgeon
nailbanger2
#6 posted 12-31-2013 12:01 PM
Sorry, Tony S., I didn’t get home last night until well after dark and the desk lamps I use in my cave don’t lend themselves too well for photography.
Thanks again for all your help, but I think the direction I’m going to head in is taking it down a little further. Does anyone have recomendations for the type of router bit I should use? MLCS has a 3/4” bottom cleaning bit that looks like my answer.
Steve, thanks for your pity, after all this is all your fault ;) I wouldn’t have it any other way, and I know I’ll get it, it will just be thinner. I’m off to work my way into the new year, and I’d like to say to you all- May the New Year live up to the hopes and wishes we all have for it. Have fun and be safe.
