Bottle Balancers
Forum topic by lazyfiremaninTN posted 344 days ago 679 views 5 times favorited 20 replies Add to Favorites Watch
lazyfiremaninTN
528 posts in 850 days
344 days ago
Topic tags/keywords: trick question
Need a little help,
What is the best angle for the bottle balancers. I am in need of some quick/easy christmas presents and thought these would do the trick.
Thanks
View Rustic's profile
Rustic
1252 posts in 493 days
344 days ago
I make mine at 45 degrees
-- There is no such thing as a mistake. Its called a design modification Rick Kruse, Grand Rapids, MI
View DonFaulk0517's profile
DonFaulk0517
50 posts in 383 days
342 days ago
I also make mine at 45 degrees. On my site I show an example of a set I made a while back. I made about a dozen a couple years ago for presents.
-- DonFaulk0517@gmail.com
View TimberMan's profile
TimberMan
106 posts in 361 days
342 days ago
I guess the hole is at a 45 as well. I don’t drink wine but think they would make a great gift. What size is the hole? It’s cheaper to ask then to go buy a bottle of wine!
View RAH's profile
RAH
413 posts in 774 days
342 days ago
I made a few of these, the hole is 1 1/4” about 7” from the bottom, I used a 45 degree cut at the bottom, another jock experimented and felt 36 degree worked well for his, the board is about 10 1/2” long and 3 1/2” wide. A lot of the balance is based on placement of the neck of the bottle.
-- Ron Central, CA
View Stan's profile
Stan
8 posts in 346 days
341 days ago
I just made a bunch with a 40 degree angle 9” long with the hole @ 6 1/2” from the bottom. The width didnt seem to matter. I made a couple out of plywood first to get the balance right. The hole doesn’t have to be on an angle. It was tough not to just drink the wine instead but I finished the holders first.
-- Thank God for Charlie Mopp's !!!!
View Kindlingmaker's profile
Kindlingmaker
1475 posts in 423 days
340 days ago
After reading the above comments, the wife said that it would be 15 minutes before supper was ready so out to the shop and back in 15 minutes with my first bottle balancer made from 3/4” falloff pine with a straight 1 1/4 hole and 40 degree miter. After the meal I went back out and made another one out of 1 1/2” salvaged redwood and this time made the 1 1/4” hole at a 30 degree angle and the miter was again 40 degrees. The bottle sets very horizontal and is much more solid on the redwood one. The later did take almost 30 minutes to make though, including the first coat of varathane. I love this site!
View MickeyD's profile
MickeyD
28 posts in 423 days
339 days ago
Yes, and the wife is pleased with the redwood one.
-- -Willing to try
Kindlingmaker
339 days ago
Sweety, do you know where the pine one is?
View rtb's profile
rtb
680 posts in 610 days
338 days ago
Mine were made at 31.5 degrees Don’t ask me why other than that my miter saw has a preset at that angle I think that the distance from the hole to the bottom is one of the keys. 1&1/4 hole straight thru. and be careful about the amount of weight above the hole or it won’t balance.
Rustic
323 days ago
Actually the hole is a straight 90 degree hole, the only miter is at the base
View PGreene's profile
PGreene
87 posts in 327 days
323 days ago
Question: When you guys say that the hole is 7” from the bottom, does that mean the hole at center? I started to make some and realized this would matter!
-- Patrick
View Broda's profile
Broda
235 posts in 416 days
323 days ago
i have made a snowman version of the bottle balancers and i know its a bit late now but i just cut a 45 and got luck the first time. didn’t need to ajust at all.
my hole is 100mm from the bottom 35mm wide and 12mm from the top
made from 22mm thick pine
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
View jeffthewoodwacker's profile
jeffthewoodwacker
487 posts in 701 days
323 days ago
Send me your email address and I will send you plans for one. Last time I sent it out it bounced back as a bad email address.
-- Those that say it can't be done should not interrupt those who are doing it.
View RAH's profile
RAH
323 days ago
The holes in mine are 7” from the bottom to the center of the hole.
-- Ron Central, CA
Kindlingmaker
322 days ago
Went online and there are as many different designs and measurements as there are woodworkers for these niffy boards. I cut my hole at1 1/4” at 30 degrees 7 ” from the bottom and the bottom is cut at 40 degrees. I think the size hole is dependent of the bottle and how you want the cant of the bottle to rest, Mine are even with the table it sits on for 750 ml bottles, (a fifth). Later this year I will experiment with some other designs and see if I can come up with a different style than I have seen so far. ...its time to work the wood.
View Vince's profile
Vince
186 posts in 326 days
319 days ago
Does anyone have any pictures of these bottle balancers?
Vince
-- Vince
Rustic
319 days ago
Look in my projects section I have a pic posted
View RAH's profile
RAH
319 days ago
Vince, I have a few posted in my projects also.
-- Ron Central, CA
View TomK 's profile
TomK
504 posts in 771 days
319 days ago
I made a dozen for Christmas gifts. I used guidance from this site: 4×10. 1 1/4 hole 7 inches from bottom. Bevel was 40 degrees, hole at 90 degrees to plane of wood. They all worked well and everyone loved them. I left them unwrapped and let recipients choose the wood species that best fit their homes.
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
View Vicsguy's profile
Vicsguy
11 posts in 440 days
317 days ago
I made several as gifts this year. I made them all 45 degrees but i did adjust the placement of the hole. I found the lower the hole the further the bottle can be placed through it. Likewise, at 8.5-9 inches the bottle was barely located in the hole. In all cases the balancers worked.
In the future I plan to use 8” lengths with the hole no more than 6.5” from the base.
