How to improve my sharpening
« back to Hand Tools forum
Forum topic by DW833 posted 12-29-2013 08:50 PM 1107 views 0 times favorited 6 replies Add to Favorites Watch
View DW833's profile
DW833
214 posts in 1845 days
12-29-2013 08:50 PM
I’ve noticed an issue while sharpening my hand plane irons and chisels. It is not until I make a micro bevel on the edge do I notice a burr. I thought a burr would develop as I sharpened. Is this expected or am I doing something wrong?
The general process of my sharpening is here.
I sharpen stanley plane irons, narex chisel’s and one veritas #4 with PMV-11 steel.
A veritas lapping plate is used to flatten flat side.
Abrasive is EZE-Lap diamond stones with a window cleaner lubricant. The course, medium and fine grits.
Polishing is done on 1500 and 2000 grit wet-dry sandpaper. Lubricant is window cleaner.
A Veritas Mk. II honing guide is used. On this guide I use the standard scale and 30% bevel angle.
After sharpening using this setup, I don’t feel a burr. But the edge does feel sharp.
I then flip knob on guide so I can create a micro bevel. After just a few strokes, a burr develops on the blade.
View Jim Wolfe's profile
Jim Wolfe
5 posts in 2192 days
#1 posted 12-29-2013 09:59 PM
Sounds like the primary bevel is greater than your guide setting and you’re not getting to the edge until you add that little extra for the micro bevel. I’d take a Sharpie and “paint” the bevel before I started sharpening so you can see exactly where you’re sharpening. How does it cut?
Jim
-- Woodbutcher and Producer of Fine, Hardwood Kindling. . .
DW833
#2 posted 12-30-2013 02:07 AM
Thanks Jim. I did try that in the past and the mark was removed during sharpening.
They cut ok. Don’t have a lot of experience with hand planes/chisels and don’t have much to compare them to.
10244 posts in 3610 days
#3 posted 12-30-2013 02:33 AM
Jim has a good theory.
If you’re not getting a wire edge, hold the iron up to the light…
if there’s a flat on the edge the light will reflect off it and
you’ll know you need to grind (or hone) away a little more
steel to get that edge acute.
View wunderaa's profile
wunderaa
248 posts in 2165 days
#4 posted 12-30-2013 03:32 AM
Ditto to Jim. At the end of the day though it is the micro bevel that’s doing all of the work. How are they cutting??
View Don W's profile
Don W
18684 posts in 2530 days
#5 posted 12-31-2013 08:53 PM
What do you mean by “I don’t feel the burr”? Look at it under a magnifying glass. The burr may be loose enough that you can’t feel it. It should definitely be there.
View Planeman40's profile
Planeman40
1150 posts in 2723 days
#6 posted 01-01-2014 04:50 AM
This is why stropping on a lather strop works so well. It breaks off the wire edge and polishes and continues sharpening the edge. the old straight razor users knew about sharpening. That’s why barbers today still put that final touch on a straight razor using a leather strop before trimming the back of your neck. I have made leather strops of all sizes and shapes for everything from plane blades (a large wide flat strop) to curved strops of various radii to sharpen carving tools and lathe gouges. Just get some leather and glue it to some wood of the appropriate size and shape and then rub some honing compound into the leather surface. Honing compound comes in various types, bar, powder, and even diamond. Just find one you like. Draw the blade BACKWARDS against the strop using some pressure. I say this because I just know someone will try the opposite.
Planeman
