Help with what router lift and table to buy
Forum topic by woodman71 posted 12-29-2013 02:23 AM 884 views 0 times favorited 6 replies Add to Favorites Watch
View woodman71's profile
woodman71
162 posts in 3287 days
12-29-2013 02:23 AM
I want to know what you guys are using and how well it works. I have been looking at woodpecker v2 and superfence anyone have one and what do you think. If anyone is using other brand what do you think and give the name.
View retfr8flyr's profile
retfr8flyr
384 posts in 1632 days
#1 posted 12-29-2013 03:54 AM
I have the Incra table mounted in my TS and plan on upgrading to the Incra Mast-R-Lift II lift next month. I am very happy with the Incra positioner system and currently use a Triton router in the table, as it works similar to a lift. I recently added the Cleansweep DC setup and it’s made it a little inconvenient using the Triton now so I am adding the lift.
-- Earl
View pintodeluxe's profile
pintodeluxe
5618 posts in 2776 days
#2 posted 12-29-2013 04:57 AM
I use a bench dog table, which is bulletproof. The router is a Freud FT1700VCE with a built in lift, and I have been very happy with it. The router may be hard to find now, but I recently bought a second one just to have a spare.
View copcarcollector's profile
copcarcollector
256 posts in 2080 days
#3 posted 12-29-2013 05:30 AM
I have the Kreg table and lift, the Woodpecker lift is the same thing in a different color. I am not as happy with the lift as I thought I would be, the large wrench makes gross height changes that are hard to control. I would have preferred something like Incra and other brands have, a top (or side) mounted crank. I may change to the Incra Mast R Lift at some point. I also like the Incra magnetic rings vs the twist in Kreg/Woodpecker style. The Kreg fence is OK. I also added the Incra Clean Sweep box to the bottom of the table, helps keep the dust down very well. Good luck with whatever you decide to buy—-
retfr8flyr
#4 posted 12-29-2013 06:10 AM
I tell you the Incra clean sweep system with Box, Wonder fence and the Clean Sweep version magnetic rings is amazing for dust control. I just finished routing several pieces last night and there just isn’t any sawdust anywhere. It all gets sucked down the throat plate or into the fence opening. I am truly impressed with it as I hated using the router because of all the dust and cleanup afterwards. Now it’s just put everything away when I finish.
-- Earl
View Lee Barker's profile
Lee Barker
2170 posts in 2813 days
#5 posted 12-29-2013 03:59 PM
I have not yet figured out the value of a router lift. I think it’s a gizmo sold with a dollop of whizbang and eventually we’ll realize we’ve been buying a styrofoam ball to put on our car antenna. Meantime, there are lots of advocates of the thing, and I suspect we’ll see, for a few years, epitaphs which include comments like, ”…and I had a router lift, too!
Just for fun, while the rest of us debate the purpose and value of a router lift, woodman71, ponder what you could do with that budget, allocated elsewhere.
Oh, and a router table fence? Two boards, a bolt and a clamp? Would that work?
Kindly (and I mean it),
View bbc557ci's profile
bbc557ci
595 posts in 2037 days
#6 posted 12-29-2013 04:47 PM
Lee - I like the way you think. My router table consists of a Corian sink cut out on a simple 2×4 frame base. Router is a big ol’ vintage variable speed Rockwell. Fence is pretty much as you described…two ash boards, but held in place with 2 clamps...guess I got a little fancy :o)
-- Bill, central NY...no where near the "big apple"
