Butcher Block Cart Question
Forum topic by Bill Swartzwelder posted 12-29-2013 01:26 AM 766 views 0 times favorited 7 replies Add to Favorites Watch
View Bill Swartzwelder's profile
Bill Swartzwelder
176 posts in 1820 days
12-29-2013 01:26 AM
My wife would like me to build her a roll around butcher block cart/cabinet, with some storage space underneath.
I plan to use Cherry and Walnut for the top, which will be a 3” thick, 24” square end grain cutting board. I was concerned about mounting the top to the rolling cabinet, because I am unsure how much an end grain cutting board expands and contracts. I probably should also mount it so it is removable for periodic cleaning/refinishing. I am just a hobbiest when it comes to woodworking. Anyone have some experience with this type of application? I have made things before that didn’t work, trying to avoid that this time. :) Also open to links to similar kitchen work carts if anyone has done a project like this.
Thanks so much!
Bill
-- What if the Hokey Pokey really is what its all about?
7 replies so far
View ShaneA's profile
ShaneA
6890 posts in 2506 days
#1 posted 12-29-2013 01:57 AM
A desk top fastner or figure 8 could handle the expansion, the end grain top should not be too prone to movement though.
View bannerpond1's profile
bannerpond1
397 posts in 1806 days
#2 posted 12-29-2013 08:51 PM
I’m in the design phase of a butcher block table for a client’s kitchen. I have come up with a way to make the movement moot. I’m going to make a frame which attaches to the four legs and is rabbeted all around so that I can drop the butcher block into the frame. I plan to make the space minimal all around to allow it to expand. This also allows me to ship the butcher block in a separate container so it can be well padded and reduce the weigh of the table itself.
You bring up an interesting point in determining the amount of movement across an end grain board. I think I will do some testing and see just how much that might be.
Be sure to post a photo when you finish and i’ll do the same.
-- --Dale Page
Bill Swartzwelder
#3 posted 12-30-2013 01:57 AM
Thanks for the replies. I found an old Norm Abram butcher block table build video, in which he also made an outer frame as you mention. He cut a taper on the perimeter of the Butcher Block and a taper on the frame, then dropped it down into the frame. It can climb up the taper as it expands. Your rabbit idea is more appealing to me.
View AandCstyle's profile
AandCstyle
2978 posts in 2165 days
#4 posted 12-30-2013 02:08 AM
Use The Shrinkulator to determine the potential movement. While the board will be endgrain on the cutting surface, it will flat grain where it meets the frame and that is where you need to allow for the expansion/contraction. I think I would go with Norm’s rather elegant solution.
-- Art
Bill Swartzwelder
#5 posted 12-30-2013 02:30 AM
So you are saying it only expands the length of the grain? So an end grain board would only get taller when wet?
AandCstyle
#6 posted 12-30-2013 02:53 AM
The length will only change by an insignificant amount. You indicated that this will be an end grain CB which indicates to me that the end grain will face the top and bottom of the board so the flat grain will be on the sides where the CB will meet whatever frame you decide to make and that is where the significant movement will occur and needs to be allowed for. Does this clarify the issue?
-- Art
Bill Swartzwelder
#7 posted 12-30-2013 02:54 AM
Got it… Thanks for the clarification.
