Large Maple Tabletop
« back to Joinery forum
Forum topic by Don posted 12-28-2013 04:54 PM 920 views 0 times favorited 4 replies Add to Favorites Watch
View Don's profile
Don
551 posts in 3243 days
12-28-2013 04:54 PM
Topic tags/keywords: question maple
Hey folks…Merry Christmas to all.
I’m starting a rather large project, a Maple table the is going to be 40” x 72” and I’m wondering about the joinery.
I’d love to run out and buy a Festool Domino system but I’d reach beyond the bottom of the pocketbook so I need alternatives.
Would butt joints be enough to keep things flat? Butt joints with batten boards? Butt joints with a dowel run through the boards to keep them in place?
Looking for advice please.
Cheers…Don
-- -- Don in Ottawa, http://www.donebydon.ca
View lumberjoe's profile
lumberjoe
2899 posts in 2249 days
#1 posted 12-28-2013 05:41 PM
What do you mean by butt joints? generally a butt joint is end grain to long grain – and is one of the worst joints if not reinforced mechanically somehow.
Careful jointing beforehand, parallel clamps, and cauls should keep it flat. If you feel the need to add some mechanical means to avoid slippage in clamps, a regular old plate jointer (biscuit jointer) will do just fine. No need for loose tenons here.
View Don's profile
Don
#2 posted 12-28-2013 06:01 PM
Sorry, I meant edge joining the boards.
The table top is going to be comprised of 6 6” x 60” x 1 1/2” boards and 1 4” x 60” x 1 1/2” board.
lumberjoe
#3 posted 12-28-2013 06:03 PM
In that case if you want the extra insurance, biscuits will do it. A domino would be overkill
View Don's profile
Don
#4 posted 01-05-2014 10:12 PM
This is the desk I’m working on for the client and I need some opinions and help with the cross grain situation where the horizontal boards meet the side boards.
Had a bit of bad luck with another project where I screwed things up by adding a decorative trim piece to a large tabletop and having the project split apart because of movement so I don’t want it to happen again.
Any help is appreciated.
Don
