Small Electrical Project (question)
« back to Coffee Lounge forum
Forum topic by dakremer posted 12-27-2013 05:18 AM 1261 views 0 times favorited 22 replies Add to Favorites Watch
View dakremer's profile
dakremer
2672 posts in 3089 days
12-27-2013 05:18 AM
I am making a DIY Soft Box (photography lighting). I need help with some wiring. I have BASIC knowledge of how to wire up a light.
Here are the pics of the sockets I have…
I have 4 of these sockets that I want to wire together into one extension cord.
Now before the safety police start yapping – yes, I checked with the “Electrical Pro” at Lowes and made sure the extension cord was big enough and that all the components (including the bulbs) were all compatible, etc, etc. And yes, I know….I know…I should probably have a professional doing this for me, as electrical work is dangerous, etc, etc, etc. Well – I’m going to do this myself, so if your “two cents” are to tell me NOT to do it….don’t bother posting :) ok…now that thats out of the way :) :) .....
I know how to wire one socket to the extension cord, but I’m not positive how to hook up all 4 of them. Especially with this type of socket, where the black and white wires are already attached to the socket itself….
Any help would be appreciated!!!
-- Hey you dang woodchucks, quit chucking my wood!!!!
22 replies so far
dakremer
#1 posted 12-27-2013 05:20 AM
When I get the wiring figured out, I will start a blog series on how to build the soft box. These are great and cheap ($50-60) lighting for taking pics of your projects, or using them for lighting during your videos, etc!
TopamaxSurvivor
18269 posts in 3673 days
#2 posted 12-27-2013 05:26 AM
Yeah, don’t do it!! ;-) But if you are going to do it, connect all the whites to the neutral and all the blacks to the hot.
dakremer
#3 posted 12-27-2013 05:32 AM
...I can connect all 4 whites to the extension cord neutral, and connect all 4 blacks to the hot?
I thought it’d be way more complicated than that…. I will have to go buy myself different Wire Connectors since I only bought ones that will hold up to two #16.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1725 days
#4 posted 12-27-2013 05:33 AM
Just put the sockets where you want them then run a black wire from one black lead to the next black lead and so on. Do the same for the whites. then tie the wire from your cord to the 1st black and the first white of your run.
View kdc68's profile
kdc68
2657 posts in 2274 days
#5 posted 12-27-2013 05:34 AM
dakremer…looking forward to seeing/following your blog….
-- Measure "at least" twice and cut once
TopamaxSurvivor
#6 posted 12-27-2013 05:38 AM
Yup, you got it.
dakremer
#7 posted 12-27-2013 05:39 AM
Kevin – this is where I get confused. I don’t know how to connect the blacks to the blacks and whites to the whites. The black and white wires coming out of each socket can’t be removed (that I know of)
View DKV's profile
DKV
3940 posts in 2501 days
#8 posted 12-27-2013 05:40 AM
-- This is a Troll Free zone.
dakremer
#9 posted 12-27-2013 05:43 AM
Thanks DKV. I get the theory of it, but have never done it, so don’t know how to apply that pictures to actually doing it…haha..
View Bluepine38's profile
Bluepine38
3379 posts in 3082 days
#10 posted 12-27-2013 05:43 AM
Wiring connections are normally made inside some type of junction box or enclosure to help enclose any
sparks or flames that might result from a bad connection. I like to do this also because it makes the
finished product look a lot neater and professional instead of having wires and wire nuts dangling around.
Have fun.
TopamaxSurvivor
#11 posted 12-27-2013 05:45 AM
put all 4 together and put one of these on it cluster.
dakremer
#12 posted 12-27-2013 05:54 AM
yeah I bought some of those, Topa – just not big enough to hold 5 wires together.
I understand parallel wiring, but I don’t get how to do it with these types of sockets because the white and black wires can’t be removed from the socket, nor does it look like I can add a wire between the two leads.
Topa, whats the different between your way and wiring it in parallel? If a bulb goes out (your way), will they all go out?
TopamaxSurvivor
#13 posted 12-27-2013 06:08 AM
When you tie them all together they are parallel. I don’t understand why you want to remove the wires from the socket. Leave they there. If they are too far apart to connect together, run a wire connecting the blacks and another connecting all the whites.
dakremer
#14 posted 12-27-2013 06:17 AM
They will be close enough to tie all 5 wires together (1 from cord, 4 from sockets). I just didn’t think you could do it that way
”If they are too far apart to connect together, run a wire connecting the blacks and another connecting all the whites.” - this is what I don’t get how to do. I’m sure its really simple for someone who knows how to do it, but i don’t understand how to actually do this…
TopamaxSurvivor
#15 posted 12-27-2013 06:20 AM
Since they are close enough, use a red or yellow wire nut and tie them together. You’ll probably have to strip the wire another 1/4” to get a good connection putting that many together.
