Making a homemade 12" disc sander
Forum topic by BrianC87 posted 12-27-2013 03:48 AM 6000 views 0 times favorited 14 replies Add to Favorites Watch
View BrianC87's profile
BrianC87
38 posts in 2156 days
12-27-2013 03:48 AM
Topic tags/keywords: question sander
I’m looking into building a 12” disc sander and was wondering what size hp motor would be the best to use for it. It looks like I would have a 1/6, 1/3, or 1/2 hp available.
14 replies so far
View waho6o9's profile
waho6o9
8164 posts in 2542 days
#1 posted 12-27-2013 03:53 AM
View distrbd's profile
distrbd
2252 posts in 2411 days
#2 posted 12-27-2013 04:06 AM
I tried building one(12” disk sander) using the following link :
http://benchnotes.com/DISK%20SANDER%20/Disk_Sander.html
The main problem for me was to cut a well balanced 12” disk out of MDF and attaching it to a 2” pulley.
I soon realized I would have a better chance of success finding a 12” aluminum disk like what you might find as Shopsmith accessory.
I ended up buying a ready made one and never looked back.
-- Ken from Ontario, Canada
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1602 days
#3 posted 12-27-2013 05:06 AM
If you decide to do it post some pics
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View mtenterprises's profile
mtenterprises
933 posts in 2658 days
#4 posted 12-27-2013 12:54 PM
I’ve done it with a 1/3 but a 1/2 would be better. When doing this – 12” disk out of MDF and attaching it to a 2” pulley – make the disk over sized by a bit then when attached to the motor you can take a chisel and cut it down like on a lathe.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View crank49's profile
crank49
4030 posts in 2936 days
#5 posted 12-27-2013 01:19 PM
Use the biggest motor you have, at least the 1/2 hp; 3/4 or 1 hp would be better.
I’d put it on a bearing mounted shaft and drive it with a belt so I could modify the speed.
View wingate_52's profile
wingate_52
224 posts in 2534 days
#6 posted 12-27-2013 05:46 PM
I made 2MDF discs, mounted them to faceplates. Put them on the lathe to true up. Added the abrasive discs. I made a table from ply with a mitre guide groove, with a plate and bar that fits into the tool rest. Add a dust hose nozzle and grind away.
View JoeinGa's profile
JoeinGa
7735 posts in 1972 days
#7 posted 12-27-2013 09:49 PM
Here’s what I made…
http://lumberjocks.com/joein10asee/blog/34349
View dbhost's profile
dbhost
5705 posts in 3197 days
#8 posted 12-27-2013 09:51 PM
Do you have a lathe with at least 12” swing? If so you just need a sanding disk and platform. Most of your work is already done for you…
View Woodknack's profile
Woodknack
11479 posts in 2345 days
#9 posted 12-27-2013 10:58 PM
I drive a 9” disc with a 1HP variable speed motor and it takes a lot to bog it down at low speeds, at higher speeds (1250 or higher) it doesn’t bog. I would build it then test with the 1/3HP but you’ll probably end using the 1/2HP.
BrianC87
#10 posted 12-28-2013 04:34 AM
Thanks everyone for the replies. I do not have a lathe at this time, but I have seen people go that route and would have been the ideal way to do it.
I’ll have to check in the morning to see what the largest available motor is that we have and go from there. I’m planning to build it based on a couple of models I have seen done here. Unfortunately I do not have a heated shop and will not be able to actually work on it until spring, but I will try to post updates at that time.
View JaySybrandy's profile
JaySybrandy
78 posts in 1541 days
#11 posted 04-26-2014 08:10 PM
1/2hp or more xD
JaySybrandy
#12 posted 04-26-2014 08:19 PM
View MrRon's profile
MrRon
4714 posts in 3208 days
#13 posted 04-26-2014 10:33 PM
I built one using a 12” disk from a Shopsmith and direct drive it with a 1/4 hp motor. The motor is not big enough. 3/4 or 1 hp would be better.
Woodknack
#14 posted 04-27-2014 02:20 AM
Ron, you could set up a pulley system and gain more torque at the expense of speed.
