what brush to use to apply epoxy as a finish
Forum topic by wiser1934 posted 12-27-2013 03:20 AM 1136 views 0 times favorited 8 replies Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3321 days
12-27-2013 03:20 AM
Topic tags/keywords: finishes brushes
need help in finding the correct brush to apply an epoxy finish to a cutting board. any information would be appreciated on this subject, I know that they have to be throw away brushes. thanks
-- wiser1934, new york
8 replies so far
View WMD2006's profile
WMD2006
95 posts in 2398 days
#1 posted 12-27-2013 03:27 AM
I’ve only used epoxy-like coatings a couple times but I’ve never used a brush. It’s always been a plastic putty knife for me. A knife or even a thin piece of wood is pretty good for spreading the finish out and for scraping away the drips on the edge.
It seems to me that if you used a brush you’d risk embedding bristles, especially if you used a throw-away.
-- -MDWhite
View JayG46's profile
JayG46
139 posts in 2032 days
#2 posted 12-27-2013 11:55 AM
A small squeegee is another option. I bought one at the grocery store for 5 or 6 bucks and cut some small notches in it so that you don’t drag too much of the finish around. When you’re done, just wipe off the excess and it will be ready to go for next time.
If you really need a brush to go over some uneven surfaces, I would suggest a foam brush since they are cheaper and will be less likely to shed then a disposable bristled brush.
-- Jay Gargiulo, Naples, FL www.swallowtailwoodcraft.com "Once you understand the way broadly, you can see it in all things."- Miyamoto Musashi
View bigblockyeti's profile
bigblockyeti
5255 posts in 1895 days
#3 posted 12-27-2013 12:25 PM
I would have to agree with Jay. Using some kind of squeegee to push the epoxy around to speed the self leveling process would be the way to go. I’ve kind of used this method, but usually only on larger projects where the epoxy was being flooded onto the surface at a finished thickness of close to 1/8”. If you could find a silicone squeegee, you could probably reuse it.
View PaulDoug's profile
PaulDoug
1613 posts in 1878 days
#4 posted 12-27-2013 04:09 PM
A foam roller spreads epoxy well. That is what I use on boats.
View Dallas's profile
Dallas
3599 posts in 2661 days
#5 posted 12-27-2013 04:26 PM
The only question I have is why are you using epoxy on a cutting board as a finish?
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3887 days
#6 posted 12-27-2013 05:13 PM
I used a synthetic fibre brush to apply epoxy and didn’t have any bristles left behind (may be I was lucky!).
I am with Dallas wondering why you’d use epoxy as a cutting board finish. I don’t think it would stand up to being cut into very much and would be really hard to refinish after.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2937 days
#7 posted 12-27-2013 06:12 PM
I have the same exact question as Dallas and Mark. The epoxy will chip off and enter your food supply. The only finish I use is walnut or mineral oil.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View gfadvm's profile
gfadvm
14940 posts in 2864 days
#8 posted 12-28-2013 01:55 AM
An old credit card or hotel room card makes a good spreader.
