A few dust collection questions
Forum topic by Allen posted 888 days ago 766 views 0 times favorited 12 replies Add to Favorites Watch
View Allen's profile
Allen
43 posts in 967 days
888 days ago
Topic tags/keywords: dust collection
I’m about 2/3rds done in setting up my own real dedicated, “No honey, you can’t put your scrapbooking junk in here and I’m locking the door” workshop. Initially I had planned to just tote a shop-vac from machine to machine as the space is rather small but this week I picked up a gently used Jet single-stage dust collector for $50 on Craigslist. So now I’m thinking about running ductwork.
I have a couple of questions about setting it up if you all don’t mind…
1.) The pipes themselves – can I use regular 4” HVAC duct at a home center or do I really NEED to buy the special “dust collection” pipes from a woodworking outlet?
2.) The only one of my tools that has a 4” dust collection fitting is my planer. The other tools to be connected are the table saw, 2 1/2” connection, and jointer, 3” connection. Would I be better off buying one of those clear pipe 2 1/2” “everything you need to hook up five machines” kits from Woodcraft or should I stick with 4” ducts and use reducers at the machines that need them?
3.) If I go the 4” pipe/reducer route is there any difference if I put the reducer at the machine end of the connection or at the blast gate?
4.) Trash-can lid separators – useful, or not worth the loss of pressure when the DC I hav is only 1HP?
5.) Last one, I promise. Since the hose connection on the jet is on top of the motor, facing upwards, it would be great if I could run the inital pipe up to ceiling level and run the main line around the top of the wall as space is at a premium. Since the DC I bought is only 1 HP, though, I’m concerned that it would make the draw too weak. The longest run of duct will only be about 6-8’. Should I run it at waist-height instead? Along the floor? I’d rather not put it along the floor or middle of the wall, only because wall/floor space is somewhat limited.
Thanks to all for any advice you can spare.
Allen
-- We may never know who let the dogs out, but I'd bet anything PETA was involved.
3041 posts in 917 days
888 days ago
The vacuum you got is barely adequate but at he price its better than nothing.
These types of machine are dependant on moving large volumes of air to the turbine and any restriction to this air flow will reduce the efficiency.
so:
1.Try to find 5” pipe and use that as the main. ( you wont have to change it when you upgrade.)
2.Make sure all the joints are sealed with furnace tape or better.
PVC will work too but is generally more expensive.
3.Make any reductions to youe piping at the tool end rather than the main or blower end.
4.The use of a separator before the vacuum is a good idea as it helps remove a lot or airborne stuff that will come back to the room through the filter bag. It also prevent stuff from hitting your turbine fan.
5.Lastly, get a better bag that the stock one that is probably on the machine now.
View Bob Babcock's profile
Bob Babcock
1808 posts in 982 days
888 days ago
Design of an efficient dust collection system is dependant not only on air volume but air speed as well. It also depends on how many machines are likely to be going at once. You really need to sit down and design the system. You may find the Jet not up to the task.
Here is a good sight that will answer all your questions and then some. http://www.airhand.com/designing.asp
Oh…and congrats on banishing the scrapbooking supplies.
Dick, & Barb Cain
7037 posts in 1195 days
888 days ago
Last fall I revamped my DC system. I had been using 4” PVC, but switched over to metal. You can see what I did on this Blog. I just changed the title of it, for clarity.
View mot's profile
mot
4903 posts in 932 days
888 days ago
You’ll also find that opinions on dust collection are numerous. The airhand site is good. Basic rules of thumb:
- make your runs as short and straight as possible.
- DC’s work on air volume, not air velocity so don’t use 2 1/2
- 5” mains may not work with a 1HP DC. It’s just asking too much…you’ll have to test it and see.
- don’t bottleneck yourself.
- in a small shop, 1 hose that gets moved from machine to machine, though a hassle, will provide much more efficient dust collection than a long run with Wye’s and blast gates.
Other than that…that HVAC piping is fine. I’d get the aluminum tape and tape all connections and then tape the length where the pipe comes together.
Watch out for the hostile debate on static buildup and dust explosions. You’ll get all kinds of advice there, mostly from people that don’t know how to spell physics, let alone understand it. Basically, if you can find a way to ground an insulator, you should qualify for the Nobel Prize…
Let us know how you progress.
888 days ago
Just to add to what Mot said , there are a lot of gurus out there in the DC Field.
Many of them do not own a proper woodshop and some don’t even do woodworking to any extent.
They seem to be the most vocal and most adamant about everything.
Re: the 5” pipes.
The average 1 hp DC just dosen’t cut it when you start running mains etc. (400-600 CFM/MIN)
The stactic pressure is quite low due to the pressure built up in the dust bag itself.
DAMHIKT
But, that is what the original poster (Allen) wanted answers to.
I suggested 5” mains as he can upgrade his system without having to tear out all the duct work later and,
it is easier to find 5/4 reducers than 4/3’s.
p.s. – see the 5” main coming out the top of the cyclone.
For what it’s worth, these things are not real good dust collecters but fairly good at chip collection.
We should all be thinking about how to reduce the fine dust in our shops as priority 1.
Cheers
MINI CYCLONE
View hermanv's profile
hermanv
15 posts in 919 days
888 days ago
Stay Away from 2.5” until your right near your smaller machines.
Install blast gates for each piece of equipment.
Keep your run as short as possible and use 4” pipe as far as you can.
Avoid using “T” connections and use “Y” conections instead.
Use a separator closer to equipment that produces heavy dust rather than right near the blower.
And one last thing – Shake the vent bag to loosen the dust to improve air flow before you turn it on everytime.
View oscorner's profile
oscorner
4572 posts in 1207 days
887 days ago
I agree…use the larger 4” and only reduce at the machine if necessary. Also, with a planer connected, having a homemade seperator is a must, otherwise you will plug up the 4” line. Don, had a blog on one and I think I pointed to a link that I made mine from, too. I have a Delta and use the clear 4” hose with 4” to 3” PVC reducers.
-- Jesus is Lord!
View mot's profile
mot
887 days ago
Bob makes a really good point. We should steer away from the conventional naming of these as dust collectors. They are not. They are chip collectors. Chip separators and hepa filters are really the only way you’ll reduce the fine dust off the tool. But alas, no matter how good your collection is, you have to take the dust off the top of the blade, reduce sanding dust off the bench and lathe, keep the fine stuff from blowing out the back of your planer and…and…and…and…filter the overhead air for all the stuff you aren’t catching….and…and…and…
Working in a small shop, I’ve come to realize a few things:
1. You can’t control fine dust. You can grab alot of it, but you can’t get it all.
2. Don’t skimp on trying to control it. You have to do the best you can.
And the final food for thought and probably my last statement on this matter:
Dust Collection is like raking leaves in the wind. You fight the good fight, but you can’t win.
I will be adding a cyclone to my shop in the very near future. I’m considering the Clearvue cyclones, but I’m looking at the Oneida ones as well.
Cheers!
887 days ago
I don’t know how this could work out for you but a guy out in B.C. put his blower in the garage and plumbed the pipes down to his basement shop. I’ll dig his story up if you are interested.
Both Clearvue and Oneida have a good following out there so you don’t have much to worry about either way.
I’ll probably make another one as I enjoy the challenge and have some experience with sheet metal.
On your other point… I agree shops are dusty. ;-)
hermanv
887 days ago
OK here it is. The everything you wanted to know but forgot to ask site.
http://billpentz.com/woodworking/cyclone/DC4Dummies.cfm#BuildItDangit
View DocK16's profile
DocK16
710 posts in 983 days
887 days ago
Your can put a ton of math into figuring out a dust colledtion system, but that sucks, pun intended. I’m no math wizzard so here’s my 2 cents based on experience. I have a jet dust collection also (650 cfm 1 1/2 hp model) I use regular 4” PVC drain pipe and it works fine but I’m reaching the limits of it’s capable of with 5 machines attached to it. I do run a ground wire to each machine ( thru the pipe) which I’ve read with descenting opinions this is necessary when using plastic pipe. I figure better safe than sorry, wire is cheap, dust explosions and fires aren’t. I had the piping run at ceiling height at first but seems to work better now at waist height. Yes the garbage can llid/cyclone is definitely worth $30, it catches 90% of the large particles. Makes it much easier when creating large amts of dust like surface planing. General rules of thumb: shorter runs give better suction, short radius 90 degree turns in the line impair good air flow, comeoff the main line with 45 degree elbows. Use a blast gate at each machine and your reducers at or as close to the machine as possible. A $30 remote switch is handy. Two or even 3 smaller units at that price are better than a $1000 cyclone. Congradulations on your own “personal space” for your shop, you’re gonna love it.
-- DocK, WV
View Clarin's profile
Clarin
1 post in 875 days
875 days ago
Well, it seemed that you’re confused on what you are doing. Check this site, Dust Collector Experts , there are useful information cited in the website. And don’t hesitate to call us concerning your problem, you can find our contact details on the site itself. Our experts are very much willing to assist and help you out.
