Finish Problem: "seams" appear days after poly is dry
Forum topic by Kwit posted 12-27-2013 01:00 AM 1262 views 0 times favorited 9 replies Add to Favorites Watch
View Kwit's profile
103 posts in 1892 days
12-27-2013 01:00 AM
I seem to have a problem with finishing some oak red oak tables made from 3.5” and 2.5” strips, 1.5” thick, glued together using TBIII, then finished with Minwax Dark Walnut
here’s a post of what I thought was a finished product:
It seems that after applying 4 coats of Minwax oil-based poly – then sprayed an apparently great finish coat – There were flaws developing nearly 3-4 days after drying. It may be a small bubble – or it seems like something is seeping out from the seams to create a very slight – be albeit – visible line at the seams in certain areas
It is not all over the pieces – just in certain areas – I built 4 tables like this.
I let my poly coats dry 24 hours – then 220 grit sand – clean with Mineral Spirits and microfiber cloths
My work shop temp is not super stable – but it has been between 62 and 57 degrees during the process
Any ideas appreciated
-- don't talk about it - be about it
9 replies so far
View JustJoe's profile
1554 posts in 1971 days
#1 posted 12-27-2013 01:04 AM
Wazzat? A picture of a snowman in a blizzard? A polar bear laying on a cotton sheet? You promised a pic of red oak – show me the oak!
Without pics, any chance it is a glue-line you’re seeing?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View Kwit's profile
#2 posted 12-27-2013 01:15 AM
Yeah – sorry about the missing pic – here’s a link to my project post
I didn’t think glue would still be an issue after much sanding, then stain, then multiple coats of poly
how long should I have waited after glue-up????
117032 posts in 3510 days
#3 posted 12-27-2013 01:55 AM
It seems that your experiencing what Charles Neil calls push back.the pores your oak has absorbed to much finish and is seeping out of the pores ,it’s possible that you did not let your walnut stain dry well enough before top coating . It would have helped to use a grain filler be for putting any finish on.
-- wood crafting & classes
16273 posts in 4151 days
#4 posted 12-27-2013 02:33 AM
I had the exact same problem on a project once. I just assumed it had something to do with moisture content and wood movement. I sanded everything smooth and added more finish coats. Once everything was perfect again, I brought the piece to its permanent home in my office. About two months later, the raised seams had returned, once again leading me to believe it is a moisture content situation.
View KnickKnack's profile
1088 posts in 3499 days
#5 posted 12-27-2013 08:06 AM
I asked a somewhat similar question 1915 days ago here.
A couple of additional ideas there that may help.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View Tony_S's profile
842 posts in 3016 days
#6 posted 12-27-2013 10:25 AM
You mentioned that you also refinished the restaurant’s existing tables. Any issues with the finish on those, or just the tables you made?
I would assume at this point that you used the same finishing process in both instances?
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View MalcolmLaurel's profile
298 posts in 1556 days
#7 posted 12-27-2013 01:51 PM
How long did the Titebond dry before coating? It develops full strength fairly quickly, but the adjacent wood has to dry out again; the water has to go somewhere and will take awhile to work its way out. If the wood is sealed with plastic varnish, it has nowhere to go.
-- Malcolm Laurel -
View Snipes's profile
163 posts in 2178 days
#8 posted 12-27-2013 04:00 PM
glue creep?
-- if it is to be it is up to me
View gfadvm's profile
14940 posts in 2623 days
#9 posted 12-28-2013 01:57 AM
I’ve seen that term “glue creep” before and suspect that is the problem (even though I’m not sure of the definition of “glue creep”.
I’ve had this problem with Titebond3 on Jatoba glue ups.
