Help needed, first scrollsawn piece.
« back to Scrollsawing forum
Forum topic by JustJoe posted 12-25-2013 03:34 PM 1282 views 0 times favorited 19 replies Add to Favorites Watch
View JustJoe's profile
JustJoe
1554 posts in 1907 days
12-25-2013 03:34 PM
Topic tags/keywords: scroll saw question scrollworking
I’m doing this ornament as my first ever scrollsawn piece. It’s going very easy – even the intricate stuff around the olive branch. But now I’m stuck on the last two cuts (the arrows point to them)
The one on the bottom is very thin. Like slightly more than a blade thick. Do I just drill a hole with a very small drill and cut a single curved slot out?
The second one just confuses me more. If I cut along the line then the entire wing will either fall off or be held on by just the little tip up top, and that wouldn’t look right.
So if anyone has seen this pattern, what’s the deal? If I can get these two lines done I might set a record for completing a project.
thanks
Joe
PS: The eye, I’m guessing I just drill a small hole for that one?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
19 replies so far
View ScaleShipWright's profile
ScaleShipWright
253 posts in 1754 days
#1 posted 12-25-2013 03:41 PM
Joe, why not just scoring them with a sharp knife? (for the 2nd cut from the point where the two wings meet)
-- God exists... But relax, He's not you!
JustJoe
#2 posted 12-25-2013 03:44 PM
You mean don’t cut all the way through, just make a relief cut?
View TheDane's profile
TheDane
5348 posts in 3532 days
#3 posted 12-25-2013 03:46 PM
Joe—I don’t have a solution, but it looks like you would have the same problem with the leaves on the olive branch.
JustJoe
#4 posted 12-25-2013 04:02 PM
I thought the leaves would give me a problem but I just went real slow around the outside edges of the branch and it came out fine. Someone more experienced would probably have gotten it even thinner but I’m happy for a first try. Here’s a shot from the back (pattern still glued to the front)
View sras's profile
sras
4681 posts in 2998 days
#5 posted 12-25-2013 04:06 PM
You have the right idea on the first cut – small drill bit.
For the second cut, just don’t go all the way to the end of the line. I would start at the top and work toward the shoulder. It looks like the grain direction is in your favor – I would leave around a 1/4 inch of the line un-cut.
View sras's profile
sras
#6 posted 12-25-2013 04:07 PM
Also – nice job on the branch!
View Tennessee's profile
Tennessee
2671 posts in 2384 days
#7 posted 12-25-2013 04:10 PM
Fantastic job on the branch. I used to do these all the time, then kind of got frustrated and a sore neck. Welcome to the wonderful world of illustrators designing ornaments who are NOT woodworkers.
JustJoe
#8 posted 12-25-2013 04:18 PM
Thanks Steve – I’ll give that a shot. Worst that happens is I ruin 1/100th of a board foot of common maple.
Paul, thanks for the compliment. I’m just going slow. I think I got this pattern from the free folder on another scrollsawing site.
ScaleShipWright
#9 posted 12-25-2013 05:36 PM
Joe, yes I was meaning that, at least for the 2nd cut. BTW good work.
View alohafromberkeley's profile
alohafromberkeley
257 posts in 2273 days
#10 posted 12-25-2013 05:51 PM
Joe, that’s the best first effort I’ve ever seen. I don’t think you need make the 2nd cut to articulate the wing.I would lightly score a line to accent the wing. I use a xacto knife handle with a tiny drill bit the same size as scroll blade as a starter hole. (I also have some of those tiny collared bits from the electronics industry, pure carbide and either called drillbits/ end mills.) Just go slow, real slow and you should have no problem with that line. I’ve been known to “cheat” a little by scoring a line with an awl and using a pencil to make a “line”....Ain’t the DeWalt an amazin’ piece of machinery?......Wes
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
JustJoe
#11 posted 12-25-2013 08:38 PM
Well it’s done. It’s not usable, but it was an easy first lesson. I made a couple of bad cuts right at the beginning, so I knew it wasn’t going to be great but I wanted to learn to make the inside/outside curves.
I tried it with the 2nd line cut out, and the line between the wings carved:
That didn’t look right to me, so I tried cutting the line partway as suggested. The blade was dull and wandered a bit, but even though I don’t think a cutout is the way to go either (although it looks better in the pic than in person.Maybe I’ll try it with a super-skinny blade) :
I do like the pattern though, so I’ll keep practicing and try it again. I think I’ll go with slightly thinner wood this time, and instead of cutting those two lines and drilling the hole for the eye I will dig out my woodburner and try to make a very fine shading of the lines and a dark dot for the eye instead.
Thanks to all of you for the help, and Wes – yes the Dewalt is great. I wish I’d have spent the money the first time I bought a scrollsaw, instead of waiting until the 4th or 5th time.
View Don1's profile
Don1
37 posts in 3619 days
#12 posted 12-25-2013 09:57 PM
I came in on this late, but if your pattern looked like this it would be easier to follow. Cut the white
-- www.oldcrowscrollwerks.weebly.com
View oldnovice's profile
oldnovice
6474 posts in 3237 days
#13 posted 12-26-2013 04:33 AM
waleedwaheed2013, check with MsDebbie about posting rules your are to leave your political/religious beliefs out of these forums.
This is a beautiful piece of scroll work!
View Don1's profile
Don1
#14 posted 12-26-2013 05:01 AM
Lighten up, Waleed, I was simply trying to help a new scroller with a pattern that he chose to cut. It is not helpful for you to interject your political agenda into a discussion regarding artwork.
Don R
View Jim Finn's profile
Jim Finn
2591 posts in 2791 days
#15 posted 12-26-2013 01:22 PM
Flag his post.
