Forum topic by Dan posted 12-24-2013 12:19 AM 1634 views 0 times favorited 31 replies Add to Favorites Watch
View Dan's profile
662 posts in 1825 days
12-24-2013 12:19 AM
A box made from Ipe and so much time spent shaping it. The lid fit to a button. A coat of finish, then time to secure the lid. Cut the 1/8” brass rods down to have room for plugs. Mixed the epoxy, dabbed a little in each hole, put the lid in position
and pushed the rods in. Went to close the lid and realized I had it upside down. I was so focused on the details didn’t even notice..unreal.
Looks like the only option here is to destroy the lid and make another. Or maybe just leave it and move on.
-- Dan
31 replies so far
View JustJoe's profile
1554 posts in 1971 days
#1 posted 12-24-2013 12:22 AM
ouch. That was going to be a nice box too. I say cut the lid off and try again.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View richardwootton's profile
1699 posts in 1888 days
#2 posted 12-24-2013 12:22 AM
Damn! I have done things like that before and it just makes you feel like a total ass! Sorry bud. Could you drill out the brass rods and go with a slightly larger diameter?
-- Richard, Hot Springs, Ar -- Galoot In Training
404 - Not Found
2544 posts in 2902 days
#3 posted 12-24-2013 12:27 AM
Rip the lid, add a strip of maple/walnut/whatever the width of the kerf, flip the handle and glue it back together. Not a mistake, a design feature.
View Dusty56's profile
11819 posts in 3621 days
#4 posted 12-24-2013 12:28 AM
Will it close nicely if you notch out the wood beneath the lift ?
View distrbd's profile
2252 posts in 2379 days
#5 posted 12-24-2013 12:35 AM
Scrap the lid and make a new one,don’t stray from the original design .
-- Ken from Ontario, Canada
View AandCstyle's profile
3004 posts in 2190 days
#6 posted 12-24-2013 12:44 AM
I agree with Richard. Drill the the rods out from the outside using one of these and install a larger diameter rod or Ipe peg. The hard part will be holding the box plumb on your drill press. Good luck.
-- Art
View BArnold's profile
175 posts in 1766 days
#7 posted 12-24-2013 12:44 AM
Richard has the solution, I think. If I’m guessing right, the brass rods are at the back edge of the lid and run into the sides of the box. Carefully drill from the outside to remove the brass rod from one side. Then you should be able to lift the top out. Next drill a matching hole through the other side of the box, clean up the old brass rods in the lid and insert new rods through the sides to hold the lid in place.
-- Bill, Thomasville, GA
View lateralus819's profile
2241 posts in 1823 days
#8 posted 12-24-2013 01:14 AM
I say cut the tongue off the lid, and leave the pocket for a finger hole. Looks quite nice actually.
View Woodbridge's profile
3535 posts in 2351 days
#9 posted 12-24-2013 01:18 AM
Fixing mistakes is part of the fun! I’d say cut the handle off the lid and do something creative to add a new handle in the proper spot. Make it a little thicker so that you can overlay part of the handle onto the top of the box to hide the joint. You might use a contrasting wood colour or carve a shell shape or something onto the new handle. Take alook at the handle on this box. If you made it a little thicker than the front you could cut it to fit the notch and sit a little proud,
-- Peter, Woodbridge, Ontario
View Dan's profile
#10 posted 12-24-2013 01:18 AM
Thanks for the support and advice guys. It’s great to have a forum like this to exchange ideas.. It looks like I will go with cutting out the lid and making a new one as I don’t want to risk ruining the carcass.
-- Dan
View bondogaposis's profile
4636 posts in 2284 days
#11 posted 12-24-2013 01:29 AM
It’s not a mistake if you can fix it. We’re all kind of chuckling at this because we’ve all been there, paying close attention to details and losing sight of the big picture. I think drilling out the pins is the way I’d go. I bet the expression on your face at that hideous moment you realized what you had done was priceless. I hope it wasn’t a Christmas present.
-- Bondo Gaposis
View kdc68's profile
2644 posts in 2210 days
#12 posted 12-24-2013 01:34 AM
Salvage your box….it’s a beauty. Drill out the pins so far is the consensus. Good luck
-- Measure "at least" twice and cut once
View PaulDoug's profile
1487 posts in 1637 days
#13 posted 12-24-2013 01:37 AM
Sorry to see that, but I bet we have all done something similar. Buck up, make another, laugh and move on.
View sras's profile
4764 posts in 3062 days
#14 posted 12-24-2013 01:38 AM
If you want to tackle the drilling idea, I would suggest starting out with an undersized bit and drill into the brass about 1/4 inch or more. Then step up to a bit that matches a larger brass rod.
Finally, but a piece of tape on the lid that says “This side up” ;)
View sras's profile
#15 posted 12-24-2013 01:39 AM
Also, no matter what you choose as a fix, there is no better feeling than triumph over a mistake!
showing 1 through 15 of 31 replies
