Wood Movement in Very Large Decorative Boxes
Forum topic by BlairHarp posted 12-23-2013 04:07 PM 1446 views 0 times favorited 5 replies Add to Favorites Watch
View BlairHarp's profile
BlairHarp
5 posts in 1646 days
12-23-2013 04:07 PM
Topic tags/keywords: box question bubinga maple
First – I have been a lurker of LumberJocks for many months. What a great community, I am ready to dive in and become a more active supporter.
I have been asked to design and build a decorative box that is rather large. Final dimensions will be around 16”Deepx24”Widex10”Tall. I am trying to determine the best method for creating the lid for this box. The lid will need to be hinged, and I would like to have a top with the look of either a solid attached top (which seems pretty risky with such a large footprint) or a frame and panel style. I intend to build the box solid and cut the top away. Creating the top as a floating panel seems to be the safe route, but I am open to other opinions.
The box sides will be Bubinga, and they would like to have a figured maple as the top and any accents (like miter splines, removable trays, etc).
So what do you think? On a rather large box what methods have worked best for you? Any creative solutions I am overlooking?
Thanks in advance
Blair
5 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2879 days
#1 posted 12-23-2013 05:14 PM
Five piece top. You’ll not have to wonder.
Go for it!
Kindly,
View Hammerthumb's profile
Hammerthumb
2853 posts in 2003 days
#2 posted 12-23-2013 08:40 PM
You could use a plywood center and miter solid boards around the perimeter. When I do that, it is hard to get the center and miters perfect, but you can install a decorative inlay where they meet. That is how I did this:
-- Paul, Las Vegas
117127 posts in 3605 days
#3 posted 12-23-2013 09:18 PM
Lee and Paul have my first two suggestions. If you use either approach you can veneer the ply to get the kind of wood you want or go with solid wood and a panel. You can also just have a solid piece of wood with battens that have elongated holes that allow for wood movement, I’ve seen a good number of miniature chest that have been done that way. lastly you could do a solid wood top with bread board ends,done properly these allow for wood movement and to help keep the top flat.
Lee Barker
#4 posted 12-24-2013 12:32 AM
Breadboard ends: great suggestion, Jim. Done to the right scale, that could be really cool.
Kindly,
BlairHarp
#5 posted 02-03-2014 05:50 PM
Thanks for the replies, sorry it took me so long to get back to this. Here is what the top ended up looking like before final finish. I think it turned out pretty good, overall there is a room for the panel to move but the fit is snug enough that it doesn’t make noise or rattle. Another change to this project is that the wood used was changed to a more simple all Walnut design.
Again – Thanks for the help, it was the push I needed to move in the direction I felt was going to be right.
Blair
