Cleaning Weathered Wood
Forum topic by MarkTheDark posted 1644 days ago 3566 views 0 times favorited 7 replies Add to Favorites Watch
View MarkTheDark's profile
MarkTheDark
10 posts in 1661 days
1644 days ago
Topic tags/keywords: cleaning bleach not sanding
I am about to use the staves from an oak barrel (white oak) to make a table, but the staves are weathered. I’d like to lighten or clean before I put a stain and finish on, but I don’t want to sand away the character of the rust stains from the rings.
Can anyone recommend a cleaning process that will take away the gray appearance? Could a bleach bath be used?
-- Mark - "Wood - it's my schtik."
7 replies so far
View Kindlingmaker's profile
Kindlingmaker
2650 posts in 1722 days
#1 posted 1644 days ago
Deck cleaner works well but you most likely will loss most of the rust or spread it.
View Toolz's profile
Toolz
907 posts in 1938 days
#2 posted 1644 days ago
You might want to try “wood bleach” i.e. oxalic acid crystals available from a pharmacy. Dissolve the crystals in water. Test on scrap first. Wear rubber or nitrile gloves.
-- Larry "Work like a Captain but Play like a Pirate!"
View RichardB's profile
RichardB
70 posts in 1685 days
#3 posted 1644 days ago
> You might want to try “wood bleach” i.e. oxalic acid crystals available from a pharmacy. Dissolve the crystals > in water. Test on scrap first. Wear rubber or nitrile gloves.
Oxalic Acid crystals are also sold at Rocklers, if there’s one nearby.
If you have the whole barrel, use some of the end boards to test things. I think I’d just try hot water and some mild soap to get dirt off; maybe use a soft scrub brush. You could use the bathtub; there’s usually a back brush nearby. hehehehe
Face it, weathered Oak is black. If you want it to look like an old barrel, it’s gonna be dark. If you want nice clean oak with rust stains, cut some duplicates , get a piece of wrought iron or the old barrel bands, polish ‘em up with steel wool, wet them, and lay them across. You’ll have rust stains in no time! ;-)
MarkTheDark
#4 posted 1644 days ago
Yes, the dark look is what I want. Perhaps it will start to “pop” once I get a stain on it. Here’s a link to what I’d like the final look to be.
http://www.buying-bar-stools.com/bistro-tables/bistro-table.html
Thanks to everyone for their input.
View CaptainSkully's profile
CaptainSkully
1187 posts in 1754 days
#5 posted 1638 days ago
I’ve had luck with sanding with 180-220. This cleans up the surface, but doesn’t sand away the barrel hoop character marks because it’s stained into the wood pores. I actually have to work hard to sand away the rings.
-- You can't control the wind, but you can trim your sails
MarkTheDark
#6 posted 1637 days ago
Capt. Skully,
I’m going to give that a try as well. I have 3 barrels worth of staves to experiment with. For time, I took the simple and safe route and just washed and scrubbed with a light detergent and water. After the stain it looks good and rustic.
View matter's profile
matter
210 posts in 1965 days
#7 posted 1625 days ago
TSP & a soft brush
I have done hundreds of feet of barnwood like this and it comes out great.
-- The only easy wood project is a fire
