glue for a glue-up
« back to Joinery forum
Forum topic by harum posted 12-21-2013 03:30 AM 1225 views 0 times favorited 16 replies Add to Favorites Watch
View harum's profile
harum
284 posts in 1637 days
12-21-2013 03:30 AM
Topic tags/keywords: question maple joining
Hello, looking for the right glue for a table top glue-up. I plan to finish the table top with a polyurethane varnish. I have read that Titebond PVA-based glues, and similar, should be only used along with screws, nails, etc., and never without reinforcement; and that polyurethane or hide glues are strong enough to be used without reinforcement of any kind. From many LJ-ers projects, my impression has been that Titebond II and III is what most people use for their table top glue-ups held by glue only. Should I be fine with Titebond II? Would appreciate any comment.
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
16 replies so far
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1631 days
#1 posted 12-21-2013 03:36 AM
Here’s a link from fine woodworking. Go pva
http://www.oldbrownglue.com/pdf/HowStrongisYourGlue_FWW.pdf
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View TheDane's profile
TheDane
5423 posts in 3657 days
#2 posted 12-21-2013 03:43 AM
I generally use Titebond I (the original with the red label) ... never had a problem.
Titebond II yields a longer open time, while Titebond III is a waterproof glue.
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#3 posted 12-21-2013 03:53 AM
I use Titebond II for most of my glueups. The glue joint is stronger that the surrounding wood fibers. You don’t need any additional reinforcement like biscuits or dowels.
View JonHitThingWithRock's profile
JonHitThingWithRock
97 posts in 1716 days
#4 posted 12-21-2013 04:18 AM
I’d go titebond-whatever, polyurethane glues are a pita, and not really that much stronger, with a table-top you have a ton of long-grain to long-grain contact, the whole needing screws thing sounds like poly-glue propaganda
View nwbusa's profile
nwbusa
1021 posts in 2280 days
#5 posted 12-21-2013 04:22 AM
To simplify my life, I just buy TB3 for my PVA glue needs. But yeah, any of the TB line will do just fine for your table, with no need for mechanical reinforcement. Dowels can be helpful for alignment but not needed for structural support.
-- John, BC, Canada
harum
#6 posted 12-21-2013 05:15 AM
Appreciate all the replies and the Fine Woodworking article. TB it is!
TheDane
#7 posted 12-21-2013 07:04 PM
FWIW … I have never bought into the line that polyurethane glues (e.g. Gorlilla Glue) is stronger than PVA.
I think it is weaker, an opinion that seems to be borne out in tests recently done by Matthias Wandel ( see: http://www.youtube.com/watch?v=MUWu-N85oXM ).
In fairness, his test was first aimed at determining the gap-filling properties, but IMHO his results also speak to strength as well.
I have had polyurethane joints fail, but never a PVA joint.
View jmartel's profile
jmartel
7879 posts in 2144 days
#8 posted 12-21-2013 07:35 PM
I just use Titebond II for everything except for cutting boards (I use Titebond III due to waterproofness for that). Buy it by the gallon and call it good.
View Bill White's profile
Bill White
4928 posts in 3954 days
#9 posted 12-21-2013 07:40 PM
PVA glues, whether Titebond or Gorilla or some other brand, are just fine.
I’ve been using the Gorilla PVA ‘cause it seems to have a quicker “grab” time. I tend to glue/assemble in component segments. It keeps me from having the panic of a big glue up with short time requirements.
Where did you find the info about PVA needing mechanical “help”?
BTW, water PROOF and water RESISTANT are totally different features.
Bill
-- bill@magraphics.us
harum
#10 posted 12-22-2013 04:41 PM
Bill, thank you for the advice. Here is the link on “mechanical support”: “http://www.naturalhandyman.com/iip/infadh/infadhe.html”. Or a quote from the source:
“Though widely used by woodworkers, PVA’s are not really suitable as a primary adhesive or for edge gluing… attaching boards together to make wide surfaces such as tabletops or other furniture. They are “plastic”, so without other supporting fasteners such as screws or nails, metal reinforcements or dowels, the glued joints will eventually break apart. For pro-quality wood gluing where extra fasteners might get in the way, read the sections in this chapter on polyurethane glue and hide glues.”
”... will eventually break apart.”—hmm…, don’t want that.
TheDane
#11 posted 12-22-2013 05:11 PM
Hmmm … never heard of Jerry Alonzy. I wonder what he bases his opinion on?
I have seen countless demonstrations (both online and at woodworking shows and seminars) that tend to prove just the opposite. In every instance I have seen, breaking an edge-glued joint that was done with a PVA (e.g. TiteBond I, II, or III) results in the wood fibers on either side of the joint failing rather than the glue joint itself. Thus it can be concluded that the glue joint is stronger than the wood itself.
I guess it comes down to a choice of who you are going to believe.
JonHitThingWithRock
#12 posted 12-22-2013 07:43 PM
I bet he was paid by gorilla to help drum up sales of polyurethane glue, might just be my inner conspiracy theorist talking
View Dallas's profile
Dallas
3599 posts in 2481 days
#13 posted 12-22-2013 07:50 PM
edited
View teejk's profile
teejk
1215 posts in 2678 days
#14 posted 12-22-2013 08:24 PM
JMartel…you must use more glue than I do! I find it hard to use the quart size bottles before they get unusable.
I have moved to TBII for everything. I really like it because I think it finishes much better than the older “yellow glues” (Elmer’s/TB I, etc).
harum
#15 posted 12-22-2013 10:24 PM
Well, formally, there is no contradiction between the two articles mentioned above. They talk about relative glue strengths at different time scales: in one article, the joints seemed to be tested shortly after glues dried; in the other, the author says “eventually”, which may mean anything, weeks, months, or years. Hard to tell…
