Arm-R-Seal and wiping it down between coats
Forum topic by ScottKaye posted 12-20-2013 08:27 PM 1241 views 1 time favorited 6 replies Add to Favorites Watch
View ScottKaye's profile
ScottKaye
576 posts in 1857 days
12-20-2013 08:27 PM
Im using Arm-R-Seal satin and had a few runs in a project I’m into. I had to get out the razer blade to scrape the runs away. They werent major, more like puddled drops. I also had to do a little more agressive sanding than I had planned (with 320) in between coats and I’m left with a very milky white haze all over my project. My question is can I wipe the surface clean with a rag wetted with denatured alcohol or should I just use a rag wetted with spring water.
Not sure if the denatured alcohol would A: melt the finish or B: leave behind any traces.
Thanks
Scott
-- "Nothing happens until you build it"
View Nobodyhome's profile
Nobodyhome
15 posts in 1540 days
#1 posted 12-20-2013 09:17 PM
Mineral spirits should be appropriate, and will do no harm.
-- John
View Drew - Rock-n H Woodshop's profile
644 posts in 2595 days
#2 posted 12-20-2013 09:27 PM
That was going to be my suggestion too, mineral spirits should work fine.
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
ScottKaye
#3 posted 12-20-2013 10:24 PM
thanks guys.. I think I have some of that laying around. Ill try it out
View chrisstef's profile
chrisstef
17172 posts in 2911 days
#4 posted 12-20-2013 11:27 PM
Thats normal for the arm r seal in my experience. I just finished a big project and the white haze was found between all 25 coats that had been sanded (over multiple pieces).
Edit – i wiped down with MS after sanding to fully answer the question. Sorry.
View Bigrock's profile
Bigrock
292 posts in 2867 days
#5 posted 12-30-2013 03:48 AM
You can use m. S. or laquar thinner which dries faster and please use finer sandpaper. Min 600
View oldnovice's profile
oldnovice
6543 posts in 3272 days
#6 posted 12-30-2013 06:01 AM
Let the spirits be with you … mineral spirits that is!
