DeWalt OR Bosch Router Decision
Forum topic by tool_junkie posted 12-20-2013 04:23 PM 15654 views 0 times favorited 21 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
322 posts in 2498 days
12-20-2013 04:23 PM
I need a new router. Been looking online for quite sometime. Found the following deal on Amazon for a DeWalt DW618PK for $146.99. Although I have been wanting to get a Bosch 1617EVSPK because the newer model has above the table height adjustment. The Bosch is selling for 199.99 on amazon. This is a $50 price difference.
The DeWalt one seems to have integrated dust collection port which is a plus, and the plus for Bosch is the above the table height adjustment.
If you were in my shoes, what would you opt for?
http://www.amazon.com/DEWALT-DW618PK-12-AMP-Fixed-Base-Variable-Speed/dp/B00006JKXE/ref=br_lf_m_8120554011_1_9_ttl?ie=UTF8&m=ATVPDKIKX0DER&s=hi&pf_rd_p=1704776282&pf_rd_s=center-2&pf_rd_t=101&pf_rd_i=8120554011&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0EJE0C7E9X275YV7FAXR
21 replies so far
View Earlextech's profile
Earlextech
1160 posts in 2659 days
#1 posted 12-20-2013 04:25 PM
Bosch
View paxorion's profile
paxorion
1107 posts in 2014 days
#2 posted 12-20-2013 04:30 PM
I was in the same boat ~6 months ago, and opted for the Dewalt DW618PK. Price was the determining factor for me. I haven’t used it enough to form a solid opinion, but from my limited usage, I haven’t been disappointed yet.
-- paxorion
View Brrman's profile
Brrman
65 posts in 2641 days
#3 posted 12-20-2013 04:38 PM
Have had my Bosch EVS for 6 years .
No issues and has been able to do everything I have needed it to do. Get’s used on almost every project.
-- "Being a perfectionist does not make one perfect..."
View pintodeluxe's profile
pintodeluxe
5624 posts in 2782 days
#4 posted 12-20-2013 04:43 PM
Well I actually have and use both of the routers in question. I must say I reach for the Dewalt more often. The Dewalt 618 is more compact in the fixed base, which makes dovetails a snap. You don’t get that tippy, top-heavy feel prevalent on so many other routers. The Dewalt plunge is comparable to the best dedicated plunge routers on the market. It will plow stopped dados, profile table edges, and most other common router tasks. But it is also incredibly accurate for pattern inlays and delicate freehand work. Not to say the Bosch isn’t accurate. It is a fine router, but the handles on the fixed base are too slick. The handles on the Dewalt are oblong, which helps keep the router vertical. As far as switching the bases out, it is no contest the Dewalt is a much better system. Just try a few Bosch display models, you might note as I have that they invariably stick and become difficult to swap out. I have the three base kit from Dewalt. I mostly use the fixed base and plunge base, but recently I put an oversized base on the D-handle base. That is a nice upgrade for edge profiling.
The dust collection on the Dewalt plunge base works great when cutting dados and mortises.
Ultimately, get the one you like best. For me the ergonomics made the Dewalt stand out.
paxorion
#5 posted 12-20-2013 05:04 PM
I’ll echo pintodeluxe’s comments, that the lower profile has been a pleasant surprise. In addition, the plunge action has been fantastic to use. A few other positives that I discovered after I started using the router:
  • The flat top and placed the router upside down after use (and the bit stops spinning!) to get it out of the way, without messing with the bit settings.
  • The collet lock which has worked very well when changing bits
  • Dust collection for the plunge base worked very well with a shop-vac. The only comparison I can speak to is the plunge and fixed base
A lot of the negatives that I read about has to do with the power cord. I’m on the fence as I always seem to struggle to find the right orientation to plug the cord in.
-- paxorion
View PaulDoug's profile
PaulDoug
1511 posts in 1672 days
#6 posted 12-20-2013 05:08 PM
I have a Bosch and it has been a work horse. 90% of the time it is mounted in my router table. I’ve had it for many years, the switch quit this year and I replaced it, I may have been able to just clean the old one and it would have been okay, but it had already gone into the trash by the time I thought of that. Like stated above it can get tricky to swap out, but keeping the motor and base clean helps. It a good router and serves me well. I have never looked at the DeWalt, so I can’t compare.
View jdmaher's profile
jdmaher
427 posts in 2548 days
#7 posted 12-20-2013 05:34 PM
If you’re gonna permanently mount it in the table, get the Bosch.
If you’re gonna use it only out of the table, either.
If you need to do both, get both.
-- Jim Maher, Illinois
View knotscott's profile
knotscott
7983 posts in 3344 days
#8 posted 12-20-2013 05:34 PM
Go handle both of them (and possibly others), and buy the one that feels best to you.
tool_junkie
#9 posted 12-20-2013 05:39 PM
So what I was thinking is that I would mount the fixed base in a router table and use the plunge base for hand held routing. With this thought, I was leaning towards Bosch since its fixed base is capable of above the table adjustment (new models). I think the question I should ask is, is this even a feasible option?
Also, does the DeWalt have a flat side on the base like Bosch has, for using it with a straight edge guide to rout dadoes?
View bigblockyeti's profile
bigblockyeti
5101 posts in 1689 days
#10 posted 12-20-2013 05:42 PM
Bosch
View lepelerin's profile
lepelerin
495 posts in 2294 days
#11 posted 12-20-2013 06:26 PM
Cannot say anything about Dewalt, I hae the bosch one, been very happy with it. No problem whatsoever with it.
I would get another Bosch if I had to replace mine.
pintodeluxe
#12 posted 12-20-2013 06:30 PM
The plunge base on the Dewalt has a flat side too.
Here is the catch.. when you reference the flat side of the base to a straightedge to rout a dado, you have to keep the edge perfectly flat against straightedge. Any rotation of the router will cause a deflection in your cut.
It is actually better to use the round edge of the baseplate for routing dados, because even if the router rotates a little, the cut will still be accurate.
Sure, you can leave the fixed base in a table and use the plunge for handheld operations. You can do that with either brand. The Bosch is like a lot of other routers like Craftsman and Porter Cable that offer partial above the table adjustments. You cannot perform all functions topside with them.
Freud and Triton are a little better in that regards. They don’t make it anymore, but if you ever come across a Freud FT1700 router, grab it. Mine stays mounted in the table and you can make all adjustments topside, which is really handy. I have two, just in case I ever have a problem!
10278 posts in 3617 days
#13 posted 12-20-2013 06:41 PM
I’ve had good luck with DeWalt routers but I haven’t used that
model you’re looking at.
These days I look at features more than brand preference. All
the pro brands of handheld power tools seem to be on
parity and at a given price point they are pretty close in
terms of what you get for your money… and it’s a lot
compared to what decent power tools used to cost.
B&D has the patent on through-the-column dust
collection though. I had a DeWalt plunger with it and
it was useful for mortising especially.
pintodeluxe
#14 posted 12-20-2013 06:45 PM
Tempted?
I just looked in the background of my pictures. It looks like a Dewalt commercial.
I think I may be biased.
View dawsonbob's profile
dawsonbob
2823 posts in 1724 days
#15 posted 12-20-2013 06:47 PM
Bosch 1617
-- Mistakes are what pave the road to perfection
