Seeking Suggestions: Fast & Easy finish for Real Wood???
Forum topic by DIYaholic posted 12-20-2013 02:26 PM 1609 views 1 time favorited 39 replies Add to Favorites Watch
View DIYaholic's profile
DIYaholic
19623 posts in 2727 days
12-20-2013 02:26 PM
Topic tags/keywords: question mahogany maple walnut curly maple finishing
My proclivity towards procrastination has me looking for a quick and easy finish, for several last minute Christmas gifts. As a newbie, most of my projects/finishes have been for shop fixtures, where I used BLO and Johnson’s paste wax. I don’t believe time will allow for an oil & wax finish, as none of the projects are even completed yet, plus pine is NOT amongst the materials list! I’m looking for something a little more appropriate, to finish off my first projects made of “real” wood!!! I’m building several clocks, some designed with an Asian inspiration, and the others in a more modern/contemporary style. Also, I am not setup to do any HVLP spraying.
Specifically, the materials in question are:
African Mahogany
Hard Maple
Walnut
Curly Maple
Local availability will determine what I eventually use. Bringing out the figure of the Curly Maple is my primary concern. Next would be doing justice for the Walnut & Mahogany. Being new to finishing, I’m looking for HALF way EASY! Being in a rush, I’m looking for FAST! So, I guess I’m really seeking a “Half-Fast” finish!!! ;^)
I would do a massive LJ search, but I’m busy in the shop, frantically building away!!! I want to thank everyone, in advance, for taking the time to respond to my desperate plea for help….
Thank you and may the force be with you! I mean, may you have a Merry Christmas, Hanukkah, Kwanza (or whatever your holiday of choice is) and a fruitful New Year!!!
Again, thank you.
39 replies so far
View Earlextech's profile
Earlextech
1162 posts in 2742 days
#1 posted 12-20-2013 02:29 PM
Shellac can be found at almost any store that sells paint. Rag it, brush it, roll it or spray. Stain under it, stain in it. Sealcoat is dewaxed shellac in case you ever want to put a different finish over it. Dries fast.
View Monte Pittman's profile
Monte Pittman
29552 posts in 2390 days
#2 posted 12-20-2013 02:30 PM
Wipe on poly goes fairly quickly. Shellac is about the fasted for drying.
View waho6o9's profile
waho6o9
8238 posts in 2628 days
#3 posted 12-20-2013 02:31 PM
+1 for dewaxed shellac
DIYaholic
#4 posted 12-20-2013 02:35 PM
Sam & Monte,
Thanks for the quick responses.
Since I need to add to my “inventory” of finishing supplies….
I’ll be picking up shellac, wipe on poly and maybe a few other things on the shelf.
Gotta love any excuse, to spend money!!!
DIYaholic
#5 posted 12-20-2013 02:38 PM
Thanks,
waho6o9!
View Jim Finn's profile
Jim Finn
2661 posts in 2974 days
#6 posted 12-20-2013 02:39 PM
I put two coats of Shellac ,sanding them both and then two coats of spray Acrylic finish. (Rust-oleum clear finish) I get both produces at Lowes. Gives a gloss finish.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View lumberjoe's profile
lumberjoe
2899 posts in 2300 days
#7 posted 12-20-2013 02:41 PM
Shellac is quick, but not that easy. It’s going to require some finesse after it cures (shellac shrinks quit a bit). Go with some rattle can lacquer. You can lay down 3 coats in an hour. It looks really nice and if you are careful you won’t hae much sanding/rubbing out to do
View RussellAP's profile
RussellAP
3104 posts in 2338 days
#8 posted 12-20-2013 02:46 PM
Shellac can have a yellowing effect on maple, poly is better.
View dbray45's profile
dbray45
3320 posts in 2828 days
#9 posted 12-20-2013 02:47 PM
Lacquer is faster and is resistant to alcohol. But is a pain to use.
If you have two days, for the woods that you list, I would MW tung oil finish – which is a tung oil poly mix – two coats and it will look nice. If you are going to shellac don’t use the box store shellac – get the flakes or buttons and mix it yourself. You can get this from Rockler, Woodcraft, Shellac.com to name a few. The alcohol you get from the box stores.
-- David in Damascus, MD
DIYaholic
#10 posted 12-20-2013 02:48 PM
Jim,
I haves me a Lowes, right here in town. I’ll be heading there in just a few minutes. Thanks!
Joe,
Thanks for the heads up!
I like it when not everyone gives the same suggestion. This gives me a variety of finishes to try out!!! Plus, I get to spend more money!!!
Headed to town, to pick up additional clock building supplies & some finishing supplies!!!
Keep the suggestions coming!!!
View Dave's profile
Dave
11429 posts in 2892 days
#11 posted 12-20-2013 03:09 PM
I vote poly. Ease and speed.
View HamS's profile
HamS
1829 posts in 2441 days
#12 posted 12-20-2013 03:16 PM
Wipe on Poly is nothing more than regular poly thinned. I use 3 poly to 1 thinner and wipe it on with the same results. I like to wipe on because my shop is far to dusty and I don’t have a finishing room.
-- Haming it up in the 'bash.
lumberjoe
#13 posted 12-20-2013 03:39 PM
My finishing schedule for poly is about 7 days. I wouldn’t call that quick. When I need a super fast finish I will sue shellac or spray lacquer. I’m pretty good with a rattle can now. I actually have really good results with the minwax stuff in the black can. 20 minutes between coats, no sanding and I just rub out the final coat with steel wool and wax.
View boxcarmarty's profile
boxcarmarty
16364 posts in 2412 days
#14 posted 12-20-2013 04:34 PM
-- My mind is like lighting, one brilliant flash, then its gone.....
dbray45
#15 posted 12-20-2013 04:37 PM
boxcar – that is actually pretty good. I use the R-O enamel because it is one of the few paints that harden when dry – unlike latex.
showing 1 through 15 of 39 replies
