Table saw base cabinet construction
Forum topic by ADHDan posted 12-19-2013 07:46 PM 2515 views 0 times favorited 3 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
800 posts in 2347 days
12-19-2013 07:46 PM
Topic tags/keywords: question
I’m going to be making a base for my R4512 similar to this – http://lumberjocks.com/projects/92257 – and I’d like to use up the piles of sheet goods I’ve got laying around. Overall dimensions are roughly 50” wide by 25” deep by 20” tall.
I’m planning to make the bottom and the sides (including a center divider/support panel) from 1” thick melamine, the back from 1/2” thick melamine, and the top from a nearly 2” thick commercial conference room tabletop (composite material, not solid wood). All the joints will be glued and screwed dadoes. Does this sound like a sufficiently heavy-duty build? Should I bolster it with hardwood supports?
-- Dan in Minneapolis, woodworking since 11/11.
3 replies so far
View JonHitThingWithRock's profile
JonHitThingWithRock
97 posts in 1960 days
#1 posted 12-19-2013 07:51 PM
I’d be surprised if that wasn’t strong enough, especially with the dados
View AlanBienlein's profile
AlanBienlein
159 posts in 2913 days
#2 posted 12-19-2013 08:56 PM
It sounds like it’s sturdy enough. When I did mine I used a piece of steel tubing under the front to prevent sagging as the solid plywood back prevent the back side from sagging.
Here is a shot during the construction of it showing the steel tubing from the front.
ADHDan
#3 posted 12-19-2013 09:01 PM
Good idea. I don’t have steel tubing on hand, but I’d bet a length of 2×4 edge-joined along the bottom would suffice.
