Grizzly Jointer Problem
Forum topic by ATLJack posted 12-19-2013 04:01 PM 1213 views 0 times favorited 4 replies Add to Favorites Watch
View ATLJack's profile
30 posts in 2219 days
12-19-2013 04:01 PM
Topic tags/keywords: question jointer
I have an older Grizzly G1182 6” jointer that I found on craigslist a couple years ago. Up until now I have not had any problems with it. Starting last week it makes a loud clank when I start it up but then it sounds normal once it is reved up. When I try jointing a board the motor looses power and bogs down the cutterhead, it comes to a complete stop after I am 3”-4” into the cut. I am attempting to make a very shallow cut and the blades are somewhat sharp. I suspect that either the motor is bad or the belt is slipping but I am not sure how I can safely find out for sure. What happens when a motor goes bad? Can it loose power like this or does it just completely stop working? How can I test to see if its the belt slipping? Any help or insight anyone can help is appreciated.
View Lee Barker's profile
Lee Barker
2170 posts in 2785 days
#1 posted 12-19-2013 07:17 PM
It’s easy to check the belt. With the tool unplugged, just squeeze the belt halfway between the motor and the head. It should deflect about an inch.
A third possibility is a slipping sheave. Check those at the same time. Check the set screws for tightness, look for a missing woodruff key.
If indeed the motor is losing power, then check the wiring connections at the switch, the plug and at the motor itself (under a plate or cover of some kind). If those are snug, and if it’s the original motor, it could well be toast. Early Grizzly motors had a less than shiny failure rate.
Fortunately it is quite easy to replace a motor on a jointer.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View pintodeluxe's profile
5595 posts in 2748 days
#2 posted 12-19-2013 07:21 PM
Belt slap at startup is a known issue with Grizzly jointers. Newer models have a belt tensioner to prevent the problem.
A loose belt might explain the belt slap, as well as apparent loss of power.
View Alan72's profile
206 posts in 1968 days
#3 posted 12-19-2013 08:13 PM
I was having a issue with my 8” grizzly which I bought in July it would make noise at start up and I noticed power loss when using. I took the cover off and the belt was fine it was the gear pull had come loose. I tightened down pully and the problem went away. I wounder if your having the same issue I did, I hope that helps.
#4 posted 12-20-2013 12:29 AM
Thanks for the replies, I will open it up tomorrow and see if I can figure out out.
