Dovetailing
Forum topic by elroy posted 12-19-2013 03:57 PM 934 views 0 times favorited 4 replies Add to Favorites Watch
View elroy's profile
elroy
1 post in 1585 days
12-19-2013 03:57 PM
I am new to dovetailing. What sized guide and bit do I need to work with wood 5/8” thick? I know a 7/16” template with 1/2” bit works fine for 1/2” thick wood.
Thank you.
View JustJoe's profile
JustJoe
1554 posts in 2003 days
#1 posted 12-19-2013 04:05 PM
I’m not sure what you’re asking. I assume since you say bit and “template” that you’re talking about a dovetail jig. Do you have a dovetail jig, if so which one? Are you looking to get a dovetail jig but want to know which jig? Are you doing through dovetails or half-blind dovetails? Bit angles are usually determined by the particular jig you use, and the manual will tell you what size bits to use on a particular thickness of wood. If you clarify your situation we might be able to come up with a less fuzzy answer.
And welcome to LumberJocks – the third friendliest place on the internet.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2778 days
#2 posted 12-19-2013 05:46 PM
On my jig there is a range of lumber thickness you can work with from 1/2” up to 1-1/8”.
For half blind dovetails you can use several different bit sizes and angles.
For through dovetails, the bit angle must match the template. So if your jig has a 7 degree through dovetail template, you must use a 7 degree bit.
Like Joe said, it all depends on your jig.
HillbillyShooter
5811 posts in 2257 days
#3 posted 12-19-2013 05:52 PM
Like the others observed, it depends on your dovetail jig. Always consult and follow the manual for your jig, and if you don’t have one, most are available on line from the manufacturer. Finally, pay particular attention to any hints or suggestions given for use of a manufacturer’s jig. Good luck and best wishes—it can be a little frustrating at first to get the hang of the jig.
View woodmizer14's profile
woodmizer14
14 posts in 1595 days
#4 posted 12-22-2013 04:44 PM
I will say that you get what you pay for, I tried a few of the less expensive before I bought my Leigh jig system . I feel that if you learn to cut hand dovetails first it makes it easier to learn the Jig of your choice.
I am thrilled that I have found this sight, Lumber Jocks Rock
-- Michael from Hickory North Carolina, michael.owenby@yahoo.com
