Plunge router table
Forum topic by Woodworker101 posted 12-19-2013 03:47 AM 1221 views 0 times favorited 4 replies Add to Favorites Watch
View Woodworker101's profile
Woodworker101
22 posts in 1746 days
12-19-2013 03:47 AM
Hi everyone,
I’ve been wanting to make a new router table for my plunge base router. I didn’t really like the way that I was adjusting the height of my router bits on my current table. I was thinking of making a router lift just like Matthias Wandel’s however I don’t think it would work with a plunge router.
Does anyone else know if there is a similar way of adjusting the height of a router bit using a plunge router attached to a router table?
-- Jackson, Australia,http://www.jacksonsfinecarpentry.com.au/
View lab7654's profile
lab7654
266 posts in 2121 days
#1 posted 12-19-2013 03:50 AM
Can you take the motor out of the base? If not, then I’ve heard of people rigging up bottle jacks under the router. Pretty creative, but I doubt there’s a lot of micro adjustment.
-- Tristin King -- When in doubt, sand it.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2687 days
#2 posted 12-19-2013 04:19 AM
Plunge routers aren’t the best for tables. Unless they have an easy way to remove the spring, you tend to fight against the plunge spring to make adjustments.
I like routers that extend high enough to change bits topside.
View ajosephg's profile
ajosephg
1880 posts in 3435 days
#3 posted 12-19-2013 06:46 PM
I have a Dewalt DW625 plunge router in my router table, and it works ok – for a hobbiest. The biggest shortcomings are the time it takes to make a major height adjustment, and the awkwardness of having to reach under the table to make the adjustment.
I removed the springs for awhile but put them back in because the router wouldn’t track small changes of the height when lowering the router. IAW, when I would turn the knob to lower the router, it wouldn’t immediately drop.
-- Joe
View Lee Barker's profile
Lee Barker
2170 posts in 2724 days
#4 posted 12-19-2013 07:03 PM
The best answer, in my opinion, is a table that is hinged and stays up at about a 45o angle. You can see the router bit to measure height or to compare to a pre-existing cut on a piece of stock.
From that angle it’s easy to remove the motor from the base for changing bits. Even with the much over-vaunted top adjust gizmo, you still have to hunker down. With the hinged top you don’t need that feature at all.
I’m strongly in Pintodeluxe’s camp on this—to put a plunge router in a table is to bury its best virtue and end up with an ill advised marriage.
A PC 690 will do everything you need to do in a table and you won’t be hearing that ringing and tootling when you turn your back. (That would be the bells and whistles, complaining they don’t get to do anything.)
Kindly,
