joining with dowels?
« back to Joinery forum
Forum topic by harum posted 12-19-2013 12:41 AM 806 views 0 times favorited 2 replies Add to Favorites Watch
View harum's profile
harum
284 posts in 1639 days
12-19-2013 12:41 AM
Topic tags/keywords: question joining dowels glue-up edge joining
I was wondering if dowels would make a difference when edge joining 1-1/2” thick and 6” wide boards into a table top? From what I have read on joinery, tightly fitting dowels may work very well for pre-gluing alignment and therefore may be worth the time without the need for any specialized tools. Would dowels at the ends also give extra protection against glue-up failure at the ends (something that some glued-up panels do)? Thanks and best wishes!
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
2 replies so far
View cabmaker's profile
cabmaker
1730 posts in 2805 days
#1 posted 12-19-2013 12:43 AM
Doubtfull
Gerald Thompson
935 posts in 2230 days
#2 posted 12-19-2013 12:59 AM
Long grain to long grain is an extremely strong joint. I use home made cauls to keep things flat and clamp the boards until I get squeeze out. Don’t put a lot of glue on the edges and don’t clamp too tight as this can reduce the amount of glue for an effective joint.
Remember glue doesn’t fill gaps so the board edges need to be jointed so they match up.
-- Jerry
