The agony of small hinges and #2 screws...
Forum topic by DKV posted 12-18-2013 11:12 PM 887 views 0 times favorited 2 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2529 days
12-18-2013 11:12 PM
After suffering through many episodes of cussing and swearing at tiny hinges and tiny screws I think I have hit on the solution.
The small racheting screwdriver is from Lowes and comes with 0, 00 and 000 bits.
The center finder is a Stanley and I had to grind the tip a bit so it would sit in the hinge hole for punching.
The screw starter is from Lee Valley but you can find almost anywhere.
And, the double sided tape to hold the hinge in place while you punch.
-- This is a Troll Free zone.
2 replies so far
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1648 days
#1 posted 12-19-2013 12:00 AM
Tiny screws (especially brass screws) and hard wood: predrill the holes, and wax the screws.
-- Malcolm Laurel - http://MalcolmLaurel.com
View theoldfart's profile
theoldfart
9740 posts in 2477 days
#2 posted 12-19-2013 12:08 AM
Also use steel screws first then replace with the brass.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
