Finger Joints with ATB blade
« back to Joinery forum
Forum topic by ChuckH posted 12-18-2013 05:05 PM 1294 views 0 times favorited 8 replies Add to Favorites Watch
View ChuckH's profile
ChuckH
70 posts in 1763 days
12-18-2013 05:05 PM
I just got a new blade, .125 kerf and ATB, I didn’t think much of it at the time honestly. I just made a test cut and there is an undeniable “V” shape in the cut – is this ATB blade going to be ineffective for anything but through cuts?
8 replies so far
View kdc68's profile
kdc68
2657 posts in 2274 days
#1 posted 12-18-2013 05:34 PM
To get a truly flat bottom cut, you will need a blade with a Flat Top Grind (FTG). Lumberjock Knotscott is the blade expert on this site. Perhaps he will see your forum question and offer advice on the best FTG blade
-- Measure "at least" twice and cut once
View RockyTopScott's profile
RockyTopScott
1186 posts in 3475 days
#2 posted 12-18-2013 05:47 PM
I use a box joint blade to get a good flat bottom result.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View pintodeluxe's profile
pintodeluxe
5657 posts in 2810 days
#3 posted 12-18-2013 07:15 PM
A 50 tooth combination blade is great for joinery work. Otherwise, any ripping blade with a flat top grind will work.
View lepelerin's profile
lepelerin
495 posts in 2322 days
#4 posted 12-18-2013 07:42 PM
here is an excellent post by Knotscott about saw blades
http://lumberjocks.com/knotscott/blog/12395
ChuckH
#5 posted 12-19-2013 08:43 PM
Well… Shucks, I feel dumb now, I read all that stuff before buying a new blade and just didn’t put it together. Thanks everyone, looks like I’m back to shopping :)
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#6 posted 12-20-2013 02:04 AM
I bought the Freud Box joint cutter blades and have been very pleased with them! They are also useful for rabbets, dados, and half lap joints. Pricy, but one of my better investments.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1718 days
#7 posted 12-20-2013 02:17 AM
Of the ATB blades I have, I used them exclusively for through cuts. I have several 50T combination blades, that’s what I usually keep on my table saw. They produce mostly smooth bottom cuts with only slight lines at the edges of the flat bottomed area. Even the side blades on my stacked dado cutter do the same.
View Dan's profile
Dan
689 posts in 1889 days
#8 posted 12-20-2013 02:28 AM
Kempston #99312 10” 24 tooth flat 32.99 on Amazon. It has worked well for me.
DanP
-- Dan
