Need Advice On Attaching A Bowed Piece Of Wood To A Plywood Edge
« back to Joinery forum
Forum topic by Targa posted 12-18-2013 03:32 PM 1062 views 0 times favorited 4 replies Add to Favorites Watch
View Targa's profile
Targa
118 posts in 1643 days
12-18-2013 03:32 PM
I’m building a bookcase using oak plywood and plan to put a solid oak edging on both the face frame and edges of the shelves.
I have some questions about the best way to attach a slightly bowed solid wood edge to a 3/4” oak plywood shelf. The edging will be about 28” long and will be 3/4” thick and 1” wide. I’m planning to make the wood edging 1” wide to both hide the plywood edge as well as to add some strength to the shelve.
The piece of oak I have earmarked for the shelf edging has a bit of a bow and I have two questions I need some advice on.
1. Since I plan to use glue and clamps to hopefully hold the edging tightly to the plywood, will the edging likely stay in place once the glue dries and the clamps are removed?
2. What will be the best method (joint or technique) to attach the edging to the plywood that should yield the best long term success?
Thank you
-- Dom
View cabguy's profile
cabguy
1 post in 1524 days
#1 posted 12-18-2013 03:49 PM
Generally, glue and clamps will do the trick. I usually put the edge so it bows toward the shelf in the middle. When you clamp the ends, the board itself is putting pressure in the middle.
View jmartel's profile
jmartel
7687 posts in 2053 days
#2 posted 12-18-2013 03:53 PM
How bad is the bow? More than likely, it will be fine to use. After you glue and clamp it, it won’t move again. Something 3/4”x1” isn’t going to have enough stress in it to warp a bookcase, so you should be ok.
Targa
#3 posted 12-18-2013 05:56 PM
jmartel asked – “How bad is the bow?”
Over a 30” length of the 8’ board I’m cutting the solid edging from the bow is about 1/8” – 3/16”
-- Dom
View Rick_M's profile
Rick_M
11090 posts in 2283 days
#4 posted 12-18-2013 06:49 PM
3/16” over 30 inches is nothing, glue will hold it just fine. I would face the convex side out.
-- http://thewoodknack.blogspot.com/
