Tung Oil Problem
Forum topic by crazicarl posted 12-18-2013 03:06 PM 1040 views 0 times favorited 9 replies Add to Favorites Watch
View crazicarl's profile
crazicarl
22 posts in 2123 days
12-18-2013 03:06 PM
First, I love LJ. I visit several times a day and love to check out what all the craftsmen in the world are making. It’s truly inspiring; keeps me thinking about what I can do next or different.
That said, I’m a novice at best and I’m finishing a walnut bench with tung oil. Every coat was diluted 50% mineral spirits. The first two coats went on fine, but I put on a third and fourth and noticed that the finish is . . . for lack of a better word, powdery. Powdery and white. As in, I can scratch the wood with my fingernail and it leaves a white powdery streak.
What have I done wrong? I’ve tried rubbing the finish down with mineral spirits alone and wet/dry sandpaper thinking I had let too much finish build up, but still with the powdery white. The wood is super smooth and when wet looks amazing, but as it dries . . . just looks dry and white and powdery. Any advice would be appreciated. I can post pics if need be.
Thanks in advance, guys.
Adam
9 replies so far
View bobasaurus's profile
bobasaurus
3530 posts in 3304 days
#1 posted 12-18-2013 03:17 PM
What is the exact brand/source of your tung oil? It might really be a water-based varnish made to look like tung oil, in which case thinning with mineral spirits won’t work very well. Also, how old is it? Did it ever freeze in a cold garage? You might just have to buy some new finish.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View dbray45's profile
dbray45
3320 posts in 2896 days
#2 posted 12-18-2013 03:27 PM
Real tongue oil won’t do what you describe – that I have seen.
Could it be “tongue oil finish” product?
-- David in Damascus, MD
crazicarl
#3 posted 12-18-2013 03:38 PM
I have 100% pure tung oil from Woodcraft. Bought it maybe a year ago, never frozen. I’m goingto try attaching some pics to illustrate my problem a little later. Thanks guys.
crazicarl
#4 posted 12-18-2013 03:42 PM
crazicarl
#5 posted 12-18-2013 03:43 PM
This is my first nice piece of furniture, so I really want it to finish out nice. Thanks again, guys.
View lumberjoe's profile
lumberjoe
2899 posts in 2368 days
#6 posted 12-18-2013 03:44 PM
How long are you waiting between coats? Pure tung oil takes several days to polymerize in ideal conditions. Also is there a specific reason you are using Tung oil?
bobasaurus
#7 posted 12-18-2013 04:23 PM
What is the temperature in your finishing area? If it’s very cold, I could maybe see this happening… otherwise maybe it’s a lack of surface prep, like dust stuck in the pores getting pulled into the finish?
crazicarl
#8 posted 12-18-2013 04:45 PM
Joe, I only waited a day between coats.
Allen, surface was very clean prior to finishing. Area was a littlecool, but never below 55
Really, I just want to know how to fix it. I do not want to have to sand it down to bare wood, but if I have to …
crazicarl
#9 posted 12-18-2013 10:06 PM
Ok, put a fresh coat of tung oil on and it looks great. After I get it.upholstered, I’ll post it as a project. Thanks for being a soundboard guys. I think the mineral spirits just dried he.fimish out.
