I really goofed and need some advice
Forum topic by Gene Howe posted 12-17-2013 11:22 PM 1237 views 0 times favorited 11 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10479 posts in 3423 days
12-17-2013 11:22 PM
I screwed up two drawer fronts really bad. Unrepairable.
The drawers are constructed of BB ply sides and backs and solid maple fronts. TiteBond II was used in rabbeted drawer joints.
Can anyone tell me how to get the TiteBond to release?
Thanks in advance for your help!
11 replies so far
View Elizabeth's profile
Elizabeth
817 posts in 3138 days
#1 posted 12-17-2013 11:26 PM
The Titebond website addresses this question:
http://www.titebond.com/frequently_asked_questions.aspx
Good luck!
View JAAune's profile
JAAune
1797 posts in 2311 days
#2 posted 12-18-2013 12:00 AM
Hot vinegar works well. Just keep applying it and slowly work at the joint with until it lets go. I used that technique once to remove some damaged veneer that had suffered from an amateur repair job.
View PaulDoug's profile
PaulDoug
1534 posts in 1698 days
#3 posted 12-18-2013 12:11 AM
I’ve had success with a heat gun, but you have to be very careful and keep the gun moving. If you don’t you will scorch the wood. A light discoloring or light scorch may be okay if it is not so deep you can’t sand it out. I would think BB and maple would scorch pretty easily. So maybe great care with a hair dryer would be better.
View gfadvm's profile
gfadvm
14940 posts in 2685 days
#4 posted 12-18-2013 02:26 AM
I have never screwed up! But I have used a heat gun to “unglue” Titebond joints. (just for fun!)
View Jim Jakosh's profile
Jim Jakosh
20472 posts in 3100 days
#5 posted 12-18-2013 02:32 AM
Hi Gene. typically tight bond will pull the wood apart in a joint if you try to break it. If is Titebond 1 or 2 you might soak it in water but take a chance on ruining the drawer bodies. If it is Titebond 3, you will have to cut the fronts away from the bodies and use a saw or chisel to get the wood and glue out of the rabbets and clean them up to accept new fronts. You can cut the bodies away with a jig saw and then use one of those multi purpose tools to remove the rest of the original drawer fronts.
Merry Christmas….............Jim
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#6 posted 12-18-2013 04:59 AM
Save yourself the headache and remake the parts. I know it feels like a waste of materials, but I have wasted valuable time trying to pull a rabbit out of a hat.
View Gerry's profile
Gerry
264 posts in 3235 days
#7 posted 12-18-2013 06:39 PM
Hi Gene,
And I have never screwed up either…........ I’ve had reasonable results using a heat gun. As others here have already said, keep the gun moving and apply a light mechanical pressure to the joint with a wedge ( chisel). Good Luck!
BTW Been a long time. Merry Christmas and a Happy New Year!
Best Regards,
Gerry Rovner
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
Gene Howe
#8 posted 12-18-2013 08:32 PM
Thanks all.
Heated the joints with an appropriated iron, squirted in some vinegar, heated some more and pried them apart. All came apart fairly clean and I will be able to reuse the rest of the drawer parts. Took about a half an hour for six joints.
View JL7's profile
JL7
8661 posts in 2960 days
#9 posted 12-18-2013 08:59 PM
This is good to know….I goof up ALOT…...glad it worked out Gene…..
-- Jeff .... Minnesota, USA
View Dallas's profile
Dallas
3599 posts in 2482 days
#10 posted 12-18-2013 09:03 PM
I have a row of 4 utility lights with 60w bulbs, (not CFL’s),
Set close to the problem, turn it on and let it sit overnight.
View Blackie_'s profile
Blackie_
4883 posts in 2507 days
#11 posted 01-02-2014 12:20 PM
Gene, looks like you got the right information from others here, a heat gun works great, I actually included a video on how to do it and how it works in one of my blogs.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
