Question about making sanding mops
Forum topic by BTimmons posted 12-17-2013 10:09 PM 2135 views 1 time favorited 12 replies Add to Favorites Watch
View BTimmons's profile
BTimmons
2303 posts in 2567 days
12-17-2013 10:09 PM
Topic tags/keywords: sander sanding sanding mop mop sandpaper
I’m looking at throwing together sanding mops in various grits. Thinking of semi-mass producing smaller irregular shaped items that would benefit from this process.
Click for details
For anyone who’s done it before, do you think that ordinary sandpaper would work, or should I opt for something with a thicker backing like the belts that would go on a belt sander? Intuitively it seems like the latter would hold up better, but I’m not sure if it would overkill either.
-- Brian Timmons - http://www.BigTWoodworks.com
12 replies so far
404 - Not Found
2544 posts in 3051 days
#1 posted 12-17-2013 10:12 PM
Don’t know for sure but cloth backed won’t disintegrate when you hit an obstacle. Emery cloth is available in rolls.
BTimmons
#2 posted 12-17-2013 10:18 PM
Hmm. The Ace hardware store down the road from my house might have it, then. I looked for emery cloth on their site and found 1 inch rolls in 80, 120, 180, and 320 grit. Not too expensive either. I think that just might be the ticket.
Thanks for the tip, Renners! (Shall we have another round of chess, by the way?)
View Oldtool's profile
Oldtool
2679 posts in 2272 days
#3 posted 12-17-2013 10:19 PM
I’ve not done this, but if I were to try, I’d look at some of the commercially available products for reference. I suspect though, that “Renners” hit the nail on the head, cloth backed would take the most abuse from sharp corners, etc.
I assume you have already looked at this LJS project: http://lumberjocks.com/projects/38242
Good luck however you decide to proceed.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
BTimmons
#4 posted 12-17-2013 10:22 PM
Oldtool, indeed. I actually linked to that project in my original post up top. I tried sending a PM to the LJ who did it but I haven’t heard back, thus prompting me to seek the wisdom of the forums. There are a few videos on YouTube on the subject but none mentioned emery cloth.
View Chris Peroni's profile
Chris Peroni
101 posts in 2020 days
#5 posted 12-17-2013 10:44 PM
When I read the email notification of your post, first thing I thought was to use emery cloth… then I checked the links and the actual post :)
-- Never discourage anyone...who continually makes progress, no matter how slow. -Plato
BTimmons
#6 posted 12-17-2013 10:52 PM
Ha! I love the internet and email. It’s orders of magnitude more effective than lighting up the Bat Signal.
View gfadvm's profile
gfadvm
14940 posts in 2772 days
#7 posted 12-18-2013 02:56 AM
Brian, I have made several sanding mops in different grits and I use drum sander paper (cloth) from Industrial Abrasives. I rip the 3” down the center to make my strips. The cheaper belt/strips were very disappointing as they came apart and shed most of the grit the first time I used them. They take a bit of time to build so I would use quality paper!
View sgv's profile
sgv
266 posts in 1974 days
#8 posted 12-18-2013 03:58 PM
I have made several, cloth back is the only way to go. I get it from a flooring place(leftover ends)
-- Tite Lines, May the wind be at your back
View lumberjoe's profile
lumberjoe
2899 posts in 2330 days
#9 posted 12-18-2013 04:11 PM
I’m not sure how wide you need the strips, but I buy cloth backed paper in rolls (for turning). Harbor Freight's stuff is actually halfway decent. 10$ for a 20ft roll of 150 ,220, 320, and 400
BTimmons
#10 posted 12-18-2013 05:27 PM
Joe, that looks like a fantastic option. And much better than paying $10 for a roll of each grit. Thanks!
lumberjoe
#11 posted 12-18-2013 05:31 PM
They take a decent amount of abuse too. I’m probably on my 10th box of these. If I thought they sucked I would have looked for better options. They handle heat really well.
View muleskinner's profile
muleskinner
897 posts in 2518 days
#12 posted 12-18-2013 05:48 PM
I did do this last summer for refinishing my garage doors. I cut up a 6×48 belt. The backing was almost too stiff. A lighter backing would have been an improvement.
-- Visualize whirled peas
