Best Practice to Inlay Hand-Cut Detail
Forum topic by Cindy Braunheim posted 12-17-2013 06:20 PM 1403 views 0 times favorited 8 replies Add to Favorites Watch
View Cindy Braunheim's profile
Cindy Braunheim
50 posts in 2701 days
12-17-2013 06:20 PM
Topic tags/keywords: box inlay question tip purpleheart maple carving shaping
Hello!
I have a very special project I am designing – a (relatively) basic heart-shaped keepsake box made of purple heart, with a Japanese character made of maple, inlayed into the top. The character will be delicate and fragile – the box top, not so much. I am enVisioning a slightly rounded top, following the imagined contour of a heart, so the inlay would need to withstand the shaping process, too.
I am wondering if there are some techniques out there that you can suggest.
Thank you!
-- Cindy in Seattle, http://visionationwoodworking.com
8 replies so far
View jmartel's profile
jmartel
8066 posts in 2236 days
#1 posted 12-17-2013 06:25 PM
I would make the character out of at least 1/4” wood. Inlay it before shaping the lid. Get some double sided tape, stick the character to the lid, then trace around it carefully with an exacto knife. Remove the character and use a router to rout out where the character goes. Get close to the line, but leave the final sizing for a chisel. Make sure it fits, then add glue, and pound it home with a mallet and a piece of scrap to even out the blows.
Cindy Braunheim
#2 posted 12-17-2013 07:38 PM
jmartel – Thank you! I was thinking along those lines myself. It’s nice to have confirmation of an idea before I attack it.
View pintodeluxe's profile
pintodeluxe
5737 posts in 2899 days
#3 posted 12-17-2013 08:02 PM
If the inlay is a simple shape, and not too intricate, a router with inlay bushing will yield excellent results. You make a template out of 1/4” mdf and carpet tape it to your project. Rout the recess in the project with the special sleeve on the bushing. Then use the same template to cut the inlay piece. Remove the sleeve from the bushing for this operation.
The pieces will fit perfectly with little or no hand work.
Whiteside makes a nice one, with a carbide bit.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4211 days
#4 posted 12-18-2013 01:03 AM
what jmartel said (unlike Willie I’m assuming that the shape is complex enough that you can’t do it with a template), with two additions:
First, you want a 3/16 or 1/8 or so router bit. Given that I had the “don’t try to rout freehand” drilled into me by bad experiences, I didn’t realize how easy it was to control a small router bit. And practice with that smaller bit before you try for real). I have found that bead stores have interesting brass or stone shapes to practice inlay with.
Second, if you get it together and discover that you’ve got gaps, break out the cyanoacrylate glue. Not the gap filling stuff, but the most flowing liquid option. Pour some in the gaps, break out the 220 sandpaper, generate some sawdust. Repeat. Can fix some truly epic goofs.
Cindy Braunheim
#5 posted 12-18-2013 05:11 PM
Thank you all for your responses – I appreciate your time and expertise.
I glued up the blank last night and will post some pics of the project on my LJ Home page later today.
Thank you, again!
Cindy
View Jim Finn's profile
Jim Finn
2666 posts in 3008 days
#6 posted 12-19-2013 02:29 AM
Have you considered trying Double bevel inlay? Done on a scroll saw. I do a lot of it and if done with thick enough woods it could be shaped the way you want it after the inlay is done.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
13624 posts in 3427 days
#7 posted 12-19-2013 02:38 AM
i make hearts from 3/4” mdf
just cut one of the heart side profile
(some look good some ‘boxy’
so i keep at it till i get a heart i like)
then slpit the mdf into two pieces
and glue them back together
and sand even
then like pintodelux shows
use the inlay bushing to cut a part and a matching setting
make the mdf template large enough
to ride the router base on
without it tipping
Cindy Braunheim
#8 posted 12-20-2013 06:10 PM
Thanks, Jim, but I don’t yet own a scroll saw –
Thanks, patron, I appreciate your tip!
