help about stain???
Forum topic by anqi posted 12-14-2008 06:53 PM 877 views 0 times favorited 7 replies Add to Favorites Watch
View anqi's profile
anqi
54 posts in 3695 days
12-14-2008 06:53 PM
Could i put Danish oil on top of oil stain? If not, what is the good coating to protect my oil stain? TIA
7 replies so far
View gizmodyne's profile
gizmodyne
1780 posts in 4323 days
#1 posted 12-14-2008 06:56 PM
What is the project?
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
View anqi's profile
anqi
#2 posted 12-14-2008 06:58 PM
This is a Shoe Rack. I also plan to make a coffe table. Thanks
View jerry mayfield's profile
jerry mayfield
36 posts in 4319 days
#3 posted 12-14-2008 07:43 PM
Danish Oil is a mixture of oil (boiled linseed oil) varnish(usually polyurethane its the cheapest)and thinner and is meant to be applied to bare wood. A few coats of wiping varnish would be fine for your projects.
Regards
Jerry
-- jerry,mlchigan
View John Gray's profile
John Gray
2370 posts in 4119 days
#4 posted 12-14-2008 07:53 PM
Ditto to what jerry mayfield said above.
gizmodyne
#5 posted 12-14-2008 08:05 PM
If you can get it in your state…. the Minwax Wipe On Poly is nice and easy. Especially if wet shoes are an issue.
View dustygirl's profile
dustygirl
862 posts in 3962 days
#6 posted 12-14-2008 08:49 PM
Thank you for the post and all the information everyone I am learning so much here at LJ.
teenagewoodworker
2727 posts in 4002 days
#7 posted 12-14-2008 08:52 PM
ya danish oil won’t be the best. its meant to soak in and the stain will somewhat seal the wood. go with a good quality wiping varnish or gel poly. i would recommend the following
Arm-R-Seal by general finishes
Seal-A-Cell by general finishes
Bartley gel stain
Rockler Gel stain (made by Bartley)
those are probably your best choices.
