7 inch dust collection ducting?
Forum topic by Jesse posted 12-16-2013 05:04 PM 3789 views 0 times favorited 8 replies Add to Favorites Watch
View Jesse's profile
58 posts in 1561 days
12-16-2013 05:04 PM
Topic tags/keywords: dust collector grizzly
I recently bought a Grizzly 3HP double canister dust collector for my new wood shop. It turns out that the inlet is 7 inches and I am having a heck of a time finding any piping and fittings that will work with this size of an inlet. I think PVC only comes in 6 or 8 inch and I’m not sure about easily obtained metal duct work? Also, I need to have elbows, straights, and Y type fittings. Of course a lot of my machines have 4 inch ports so I need to be able to reduce at the machine, not sure if metal ducting has options for this?
I found a few places online that want what seem to me to be crazy amounts of money for the fittings so I am wondering what you all use? I really don’t want to take it down to 6 inch unless I have to. I want to do it right (this is my huge dream shop I’m building here) but I don’t want to spend as much on 40 foot of pipe as I did on the machine itself. Any help is appreciated, thanks in advance!
8 replies so far
4909 posts in 2429 days
#1 posted 12-16-2013 05:29 PM
Deleted, it was a double post.
#2 posted 12-16-2013 05:37 PM
Mine has a 7” inlet, and Oneida suggested I run 7” for at least the first 5-6 feet before transitioning to 6”. So I used 7” HVAC snaplock and 2-7” HVAC el’s to run the duct up to the ceiling, then transitioned to 6” PVC. If you choose snap lock, be sure to get the heaviest gauge you can get; a lot of guys have collapsed the 30 gauge stuff. The transition to PVC is fairly easy to do, though it’s not particularly attractive. A 7×6 HVAC transition (reducer/enlarger) will do it, as for the appearance I’m a function over form guy (really don’t care what it looks like). Here’s what I did to my drum sander to get a 6” port on it. Like I said I function over form, and this works really well.
View shipwright's profile
7940 posts in 2733 days
#3 posted 12-16-2013 06:40 PM
This is the second time in a couple of days that I have posted this reference. It is a good solution to the high cost of fittings.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View descolada's profile
54 posts in 1733 days
#4 posted 12-16-2013 10:56 PM
I had the same problem looking for 7” duct in my system recently. If you want to go the sheet metal route (as i did) penn state has pretty reasonably priced. I bought my system using their economy line and it it was a bit of a pain trying to connect everything using duct tape, but worked great once installed. You can find it here:
When I went to expand the system I used their economy pieces except i switched in the premium drawband connectors. At 7” they are $20 each instead of $10, but much beefier and easier to install.
View Jim Finn's profile
Jim Finn
2641 posts in 2857 days
#5 posted 12-17-2013 03:55 AM
I put in a six inch system all of 24 gage steel. I am a retired sheet metal worker so I made the wyes myself and bought the ells. You could get a sheet metal shop to make a taper for you to fit PVC and use PVC from there to the equipment. It would be one rather expensive fitting but only one.
View copcarcollector's profile
256 posts in 2053 days
#6 posted 12-17-2013 05:32 AM
I have that exact dust collector. I ran a small amount of 7 inch metal pipe to turn the corner and go up wall, then used an adapter down to 6 inches for all of the main runs and drops.
#7 posted 12-17-2013 09:14 PM
Having the exact same dust collector, how do you like it so far? I haven’t used mine yet
View Holbs's profile
1819 posts in 1965 days
#8 posted 03-04-2014 02:37 AM
i’m in the process of doing all this myself. gots a blog going with building a Thien Baffle (still in progress).
Everyone that has a grizzly 3HP dual canister says they have 7” inlet. While mine is 6”.
I was lucky.. I have a friend at a HVAC distribution supply house. I get my 6” why’s for $3 and snap lock 5’ for $7 (all 26 gauge).
Was about to fiddle with the wye’s… then I found out they are facing the wrong direction. Unsure what to do about it! Grr…
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
