treating green pine boards
Forum topic by jetsonFUVA posted 12-16-2013 05:00 PM 766 views 0 times favorited 2 replies Add to Favorites Watch
View jetsonFUVA's profile
4 posts in 1559 days
12-16-2013 05:00 PM
Topic tags/keywords: green lumber staining green lumber bora-care
I had pines cut down in aug, milled in early Nov, and am using them now for an out building. (2×6) rafters, and boards 1” x 8”-10” board. I realize you should wait til wood dries, but I decided to put it up now, a time factor for me and when I could do project. I was planing on dipping ends of 1 x in oil based stain to help preserve/treat lumber, then maybe a coat of stain once now and again in spring ( I live in central VA)
Is this worth my time, or should I wait for wood to dry more while hanging? Or would I be better off painting the ends, or waxing them? I also have some Bora-Care, I was planning on hitting the bottom 2’ of the wood with that. So am I wasting my time, seeing as the wood is not dried yet? And how does the Bora-Care work with oil based stain?
2 replies so far
117032 posts in 3512 days
#1 posted 12-16-2013 05:05 PM
Not sure what kind of pine you using,if it’s sugar pine or any other soft pine ,it is not a good choice for rafters wet or dry.
-- wood crafting & classes
#2 posted 12-16-2013 10:52 PM
It’s white pine, true 2×6, should work fine for rafters, 18” separation. I used what I had, but local consensus from builders say it will be fine. Treated 2×8 double up under them
