Natural edge cutting board - Need help
Forum topic by maggiem posted 12-16-2013 04:49 PM 2058 views 0 times favorited 22 replies Add to Favorites Watch
View maggiem's profile
9 posts in 1558 days
12-16-2013 04:49 PM
I bought a kiln-dried slab of black walnut to make a natural edge cutting board. When I bought the slab, it would lie flat. After removing the rough bark and sanding it, it now rocks slightly when placed on a counter top. Not an ideal result, since I made it as a gift for someone. It has not gotten wet, so it is not warped, I believe this is the result of removing the bark. I do not own a planer. What is the best solution? I thought about adding feet, which I could sand down to level the board. Is that a good solution, and if so, what is the best way to do that?
22 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2296 days
#1 posted 12-16-2013 05:41 PM
Put it in a 250 degree oven for a couple hours to see what happens. It’ll either flatten out or (probably) get worse, which can only be fixed by planing/sanding.
Shawn Masterson
1324 posts in 1884 days
#2 posted 12-17-2013 12:55 AM
Feet would be the quick way
View retfr8flyr's profile
381 posts in 1604 days
#3 posted 12-17-2013 03:34 AM
If you have a local cabinet shop they will usually run it through the planer for a few bucks.
-- Earl
#4 posted 12-17-2013 06:00 AM
Thanks, Guys. I’ve tried everything and all of the above except having someone run it through a planer. I guess I’ll try that tomorrow. If that doesn’t work, I’ll just have a really pretty piece of firewood…that won’t lie flat. Thanks, again.
View robert triplett's profile
robert triplett
1566 posts in 3040 days
#5 posted 12-17-2013 03:11 PM
If you have a 6×48 belt sander, you can use it to flatten wood. see my other response in another post today.
-- Robert, so much inspiration here, and now time to work!!!
View dbray45's profile
3315 posts in 2712 days
#6 posted 12-17-2013 03:38 PM
IF your board is glued, heating it to 250 will fail the glue.
Use rubber feet on the corners, if they are fairly soft, all will be good – and it keeps the board from sitting in water on the counter.
-- David in Damascus, MD
View quvia's profile
103 posts in 1602 days
#7 posted 12-17-2013 06:09 PM
Park your car on it over night.Just kidding. I use wood buttons on the corners if warped a little.
-- Ted ,Conesus,N.Y.
View WibblyPig's profile
172 posts in 3210 days
#8 posted 12-17-2013 06:31 PM
If you’re in St. Louis, feel free to contact me and we can run it through my planer.
-- Steve, Webster Groves, MO "A society grows great when old men plant trees whose shade they know they shall never sit in."
Shawn Masterson
#9 posted 12-18-2013 03:32 AM
not to throw a wrench in the works, but is it long grain or end grain? long can be planed, end grain has to be sanded.
just an FYI
#10 posted 12-18-2013 07:40 AM
Thanks for the tips, Robert. I read your other posts. I did try sanding it, but it’s a pretty pronounced twist, and it is not a thick piece of wood…especially now that I have sanded the heck out of it.
#11 posted 12-18-2013 08:12 AM
Shawn, David – It is not glued because it is not an end grain nor an edge grain. It was a live edge slab of black walnut that did lie flat when I first got it. I removed the rough bark, sanded it down and applied a beeswax and oil mix.
However, removing the bark apparently released some pressure that allowed the twist to come out. I chose the piece because I like the rustic look and I think the colors and the texture of the grain are really nice, so I’m very disappointed with this unexpected twist (pun intended). I did try putting in in the oven as a last resort, as I had seen that mentioned elsewhere. However, that may have made it worse. The twist is so pronounced that feet at each corner will not work. I’m thinking of using two pieces of 1” x 2” x 6” (or 8”) blocks, placed a little closer to the center where it is straighter, as a sort of platform to stabilize it, then I can sand the blocks to level them. I still think it is pretty so I hate to give up, although I did briefly consider running over it with my car as Ted suggested, but that was just the frustration talking. This probably goes without saying, but I am new at this.
View Woodendeavor's profile
276 posts in 2542 days
#12 posted 12-18-2013 12:36 PM
I would not give up on this piece. The picture was worth a thousand words. This piece of wood with the knot in the center stands a great chance of movement seasonally. The grain runs in a different direction through the knot and as seasonal expansion and contraction occur I would put money on this board warping and twisting. I think soft feet would be your best bet to help counteract this seasonal movement. It is a beautiful piece of wood, don’t give up on it
robert triplett
#13 posted 12-19-2013 03:06 AM
Here is another thought. Go a different direction and cut the slab into 2” wide strips. Recut to take a thin slice (just skim on a tablesaw) off of each side to get a 90 degree surface. Reglue, either with contrasting strips or just to each other. This takes a lot of the twist out. If you can use a bandsaw the kerf would be minimal. I use the 6×48 belt sander to touch up the cuts. Some Yellowheart or Redheart could look good with that piece.
#14 posted 01-01-2014 06:30 AM
Hey, Guys, I finished the cutting boards and though my “rustic live edge slab cutting boards” are nothing like the beautiful end grain and edge grain boards I’ve seen on this site, I think they turned out okay for a first time rookie Lumberjock, like me. Even though I have definitely caught the bug, there were many mishaps along the way. I have a humor blog and I am writing about my adventure in woodworking for my next post. I’d like to mention Lumberjocks, your suggestions, and how nice and helpful you were. I won’t use your names or nicknames if you do not want me to, but if it is okay for me to mention you guys and the forum, I will send you a link to the blog as soon as I am finished writing the post. Just let me know.
Thanks again for responding so quickly with all your help and suggestions. Happy New Year!
View UncleStumpy's profile
734 posts in 2248 days
#15 posted 01-01-2014 06:42 AM
I have been doing this happily for 10 years, am self-taught and mistakes are part of the education.
I find it extremely satisfying when I can turn a mistake into something cooler that what I had planned – it happens all the time. So welcome to our own version of addiction!!!
How can we read your humor blog?
-- "They don't want it perfect - they want it SPECIAL"
