Waterlox / Air Bubbles
Forum topic by handystanley posted 12-15-2013 09:06 PM 1507 views 0 times favorited 1 reply Add to Favorites Watch
View handystanley's profile
169 posts in 2847 days
12-15-2013 09:06 PM
Topic tags/keywords: waterlox air bubbles question
Last night I applied the fifth coat of Waterlox on a walnut bathroom countertop that I am building / finishing. I have applied the Waterlox per the instructions using a natural bristle brush and I did not shake the can in the process – if anything I may have smoothly rotated it. When I checked the backsplash this afternoon I noticed a number pin size air bubbles.
Regardless on how they got there what should I do now to remove these air bubbles? Should I use sandpaper with a grit higher than 220? Any other suggestions? Thanks!
-- "Projects beget projects and projects beget the need to buy new tools and that is what the cycle of life is all about." Stan Pearse, Novato, CA
1 reply so far
View hydro's profile
208 posts in 1686 days
#1 posted 12-15-2013 10:23 PM
Let the last coat cure thoroughly, then slice the bubbles off with a sharp card scraper. Smooth the surface with 220 paper then re-coat.
To avoid bubbles when applying a conversion varnish coating with a brush, try heating the finish on an old coffee maker hot plate. The hot varnish will be much less likely to retain the bubbles formed by brushing.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
